how to check traffic on cat 6513
sayhi2shashi
Can anybody tell me ,
what can cmd "show ip cache flow " will give and also how do i can check the current traffic which is flowing on the 6513 switch. (viz source ip, des ip, protocol, portnumber)
Pls let me know
regards
Shashi
tapas_rc123
The " Show ip cac flow" gives the current trafic flow from the router.. this command shows the details such as the Src IP, Dest IP, Src Port, Dest Port, Packet count.. Etc. But to use this command you need to enable the cac flow.
Tapas
Hi Tapa,
can u let me know ,on which configuration mode this cmd has to be entered (enableing cac flow), Can use let me know the syntax,
regards
Shashi
