how to clear the interfaces counter in cisco switches
I need to monitor the number of packet drops per day, when I was using command " show int | inc line | drops " showing overall drops of the interface.
But I've already cleared this packet drop issue. So I need help to clear all the previous drop values. So please advise to help me.
2 Accepted Solutions
Leo Laohoo
To clear ALL interface counters:  clear count [Enter]
To clear one specific interface counter:  clear count <PORT> [Enter]
Hi Khaleel,
There is nothing harm to your devices running the following commands.
clear counters >> This will clear counters values for all the interfaces.
Clear counter int g1/0 -- this will clear only for one particular interface.
 (this will clear the values which are on the interfaces:-
Input/output drops counters value
CRC/Input/outut errors.)
No need to worry to run these command on the production network. It just clear the counters of the interfaces and does nothing harm to the traffic flowing.
example:-
#show int g5/1 | in up|drops
GigabitEthernet5/1 is up, line protocol is up (connected)
  Full-duplex, 1000Mb/s, media type is SX
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 608766710 >> Drops are seen.
I did clear counters and now you can see the tod value is o.
#clear counters gigabitEthernet 5/1
Clear "show interface" counters on this interface [confirm]
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0 >> it is 0 now.
No issues with my traffic.
Inayath
*Please dont forget to rate if this info is helpfull.
10 Replies 10
Leo Laohoo
If I could use the command "clear counter" is there any other problems  to occur.
Hi Khaleel,
example:-
Inayath
Hi Inayath,
Your replay is more useful to myself
herewith I've attached the implementation log for your reference.
thanking you
Khaleelur Rahman
Looks clean now :-)
Thank you sir , much appreciated
I have applied this it works, just kindly confirm by doing this resolves the issue by which it occurs or it can occur again
kindly let me know if this occurs by fiber cable or SFP or any other issue can cause this.
mohamed hosseny
check the below commend
Switch#show interfaces Gi1/10 | in CRC
jiarluo
Hi team,
Is there any documentation to support the claim that this command will not affect traffic?
The command to clear the counters will not affect traffic.
