How to configure ADSL PPPoE conexion withount interface ATM on the cisco 1941 router
aefmaaradji84
Hello i do this configuration but i can't insert "dsl operating mode auto" and "pvc 0/38" into the interface giga0/0
when i made my modem in the bridge mode the following configuration does not work, i can't receive the ip adresse from the ISP
please can you help for this problem
interface GigabitEthernet0/0
description Dsl Interface
no ip address
ip mask-reply
ip directed-broadcast
ip flow ingress
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
interface GigabitEthernet0/1
description LINK_INSIDE
ip address 10.11.0.254 255.255.0.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap pap callin
ppp chap hostname djnassim
ppp chap password 0 ************
ppp pap sent-username djnassim password 0 ************
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list DSL_ACCESSLIST interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended DSL_ACCESSLIST
permit ip 10.11.0.0 0.0.255.255 any
access-list 23 permit 10.11.0.0 0.0.255.255
thank you for your help
yes you can there standard atm commands
7 Replies 7
Mark Malone
Hi if your isp supplied an atm pvc configuration that's the underlying layer 2 technology that they use to transport your traffic you need an  an atm interface module on your router or ask them can they provide Ethernet instead there's no config that will get you around that as it's the physical transport type they use
dear mark malone
in the case that the ISP provide just PPPOE, is there solution using an upgrade of IOS or by integrating a new card interface ?
- if the solution is in IOS what is the upgrade that I need it (that support the PPPOE protocol)
- If the solution is in card, what is the name of cards that can i use it
please i need a solution in a brief time
Please help me
best regards
I have this informations of IOS .
SG#sh version
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.4(3)M1, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Sat 25-Oct-14 01:02 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
RtSG uptime is 1 minute
System returned to ROM by power-on
System image file is "flash0:c1900-universalk9-mz.SPA.154-3.M1.bin"
Last reload type: Normal Reload
Last reload reason: power-on
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
If you require further assistance please contact us by sending email to
export@cisco.com.
Cisco CISCO1941/K9 (revision 1.0) with 491520K/32768K bytes of memory.
Processor board ID FCZ191760V0
2 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
255488K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*1        CISCO1941/K9          FCZ191760V0
Technology Package License Information for Module:'c1900'
Technology    Technology-package                  Technology-package
              Current              Type           Next reboot
ipbase        ipbasek9             Permanent      ipbasek9
security      securityk9           Permanent      securityk9
data          None                 None           None
NtwkEss       None                 None           None
Configuration register is 0x2102
SG#sh license
Index 1 Feature: ipbasek9
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
Index 2 Feature: securityk9
Index 3 Feature: datak9
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
Index 4 Feature: NtwkEssSuitek9
Index 5 Feature: ios-ips-update
Index 6 Feature: hseck9
Index 7 Feature: mgmt-plug-and-play
Index 8 Feature: mgmt-lifecycle
Index 9 Feature: mgmt-assurance
Index 10 Feature: mgmt-onplus
Index 11 Feature: mgmt-compliance
its hardware issue and the card depends on your ISP whether there annex a or b etc
heres the pdf with the supported wan modules for ATM for 1900
http://www.cisco.com/c/en/us/products/routers/1900-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
Broadband 4451-X 3900 2900 1900
EHWIC-VA-DSL-A   Multi Mode VDSL2/ADSL/2/2+ EHWIC Annex A
Data Sheet  Q&A
EHWIC-VA-DSL-B   Multi Mode VDSL2/ADSL/2/2+ EHWIC Annex B
Data Sheet  Q&A
EHWIC-VA-DSL-M   Multi Mode VDSL2/ADSL/2/2+ EHWIC Annex M
Data Sheet  Q&A
EHWIC-4SHDSL-EA   Multi Mode EFM/ATM SHDSL EHWIC
Data Sheet  Q&A
HWIC-4SHDSL-E   4-pair G.SHDSL HWIC with 2-wire, 4-wire, and 8-wire support
Data Sheet  Q&A
HWIC-2SHDSL   2-pair G.SHDSL HWIC with 2-wire and 4-wire support
Data Sheet  Q&A
dear mark malone
Hello again,
if I add the ATM WAN modules for 1900, can I use the commands below without adding anther licence of IOS
Commands: "dsl operating mode auto" and "pvc 0/38"
Thank you in advance for your help.
Thank you so much mark malone
aefmaaradji84
Please is there a solution for this ?
- There is not the ATM interface
- There is a connexion PPPoE of the ISP.
thank's you for help
