Showing results forĀ
Search instead forĀ
Did you mean:Ā
How to configure LACP load-balancing on Catalyst 1000 series
handewo
Command "port-channel load-balance " is not recognized on c1000 switch.
Does c1000 switch support modify load-balancing methods?
Is there any document addresses if c1000 support this feature?
What is the default  load-balancing methods that I cannot find anywhere on c1000 switch?
I'll very appreciate your answer!
