How to copy Cisco C9300L IOS and Bootstrap to USB drive
msmithx113
I accidentally bricked my Cisco C9300L switch and no longer has IOS or Bootstrap.   Can I save copy of IOS and Bootstrap from my  other Cisco C9300L switch and save to USB drive?  Then copy images onto the switch that is inoperable?
balaji.bandi
yes if that is .bin file available on the switch.
plug the USB to other Switch copy the .bin file from the working switch.
Plug in to the switch do not have IOS XE and follow below steps to recover :
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/217607-troubleshoot-and-recover-catalyst-9000-s.html
BB
Leo Laohoo
IF the switch is in ROMMON, it is not possible to copy the BIN fine into the flash.
The only options are to boot the firmware from the USB or to use the command "emergency-install usbflash0:filename.bin" to put the packages back into the switch.
