how to safely turn off cisco router/switch?
wxpsaint98
is it just turn off the power switch at the back of router/switch
or need to issue soem command in user EXEC mode /privileged mode to shut down the router/switch? explain please, thank you
7 Replies 7
a.alekseev
Level 7
Level 7
You needn't any commands for doing this.
ohalnet53
there isn't a "shut down" command for those active devices.
you must physically turn off the power.
Kevin Dorrell
Level 10
Level 10
Provided you discipline yourself to save the configuration each change, then you can simply remove the power or switch off. If in doubt, save the configuration to NVRAM before you switch off. But there is no concept of "closing down".
Kevin Dorrell
Luxembourg
Hi Kevin,
The only command that would be close would be the 'reload' command but this just reset's the router.
Hope this helps, Please vote below if so.
Justin
You can turn off all the power supply remotely to shutdown the switch. It works well with cat9300.
Cat9300 standalone switch:
conf t
power supply 1 slot a off
power supply 1 slot b off
Cat9300 two switch stack:
conf t
power supply 2 slot a off
power supply 2 slot b off
NOTE: you will loose the remote connection and need to reseat the power cord to turn the switch up.
On the 9300s I have, it's done from exec, not from conf t
Amit Singh
First use below commad to identify the power supply connected -
Switch#sh inventory
NAME: "c93xx Stack", DESCR: "c93xx Stack"
NAME: "Switch 1 - Power Supply A", DESCR: "Switch 1 - Power Supply A"
PID: PWR-C1-715WAC-P , VID: V01 , SN: XXXXXX
Then in exec mode turn OFF the power supply.
Switch#power supply 1 slot A off
