How to Determine Sup720 RP/SP Flash/DRAM Sizes
Darren Roback
Level 5
Level 5
Hello -
I have a 6509E chassis with redundant Sup720's that were purchased at different times, and as such, have different sizes of SP/RP DRAM and flash.
I would like to understand the proper way to verify current
Determining SP DRAM:
1. Execute 'show version' from privileged exec
2. Note the size of listed memory
     2a. In my case, the listed size was '458720K/65536K bytes of memory'. By adding these two numbers together and dividing by 1024, I can come to the           conclusion that I have 512MB of SP DRAM on my Sup720.
Determining SP BootDisk:
1. Execute "dir sup-bootdisk:"
2. Note the size of the listed memory
     2a. In my case, the listed size was '512106496 bytes total'. By dividing by 1024, I can come to the conslusion that I have 512MB of SP Flash.
What I am unclear on is how to check my RP DRAM and Flash. Does anyone have any pointers on this? Also, what is the difference between sup-bootdisk and sup-bootflash?
Thanks!
Darren
Marvin Rhoads
Route processor DRAM is either 512 MB or 1 GB, varying according to the type of Sup 720 you have (show module). See table 2-14 here.
Also shown in that table is that RP bootflash is 64 MB for all Supervisor 720 models.
You may also find this link useful:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/qa_c67_457347.html
