Segment from PIX to segment on ASA continued...
Tyler Woods
This is a continuation of the the thread that can be found here:
https://supportforums.cisco.com/message/4100237#4100237
I need the following to happen:
Host at 12.x.x.134 to access host 10.50.2.32 on port 8888.
Host at 12.x.x.134 to access host 10.50 2.33 on port 1560.
I am at a complete loss on getting this accomplished. Have tried multiple configurations and nothing works. Ideally I would collapse this all to the ASA but I do not have the time to dedicate at the moment so I just need to get this working as it is. The ASA is under SMARTnet but CCO ID does not have permission to its serial number yet.
Any guidance on this would be greatly appreciated. Is below enough to go on?
ASA Interfaces
Ethernet0/0 outside 64.xx.xx.130 security-level   0 --> to RouterA via 2980
Ethernet0/1 inside  10.50.2.1    security-level 100 --> to 2980
Ethernet0/2 dmz1    10.10.10.2   security-level  50 --> to ASA e2
PIX
Ethernet0   outside 12.xx.xx.2   security-level   0 --> to RouterB via 2980
Ethernet1   dmz     12.x.x.129   security-level  50 --> to 2980
Ethernet2   dmz2    10.10.10.1   security-level  50 --> to PIX e0/2
Jon Marshall
Tyler
I think the issue may be this line on the pix -
nat (dmz2) 0 10.50.2.0 255.255.255.0
this is Identity NAT. Basically it says don't translate 10.50.2.x addressing going to the pix. But it is only one way ie .from the ASA to the pix. I don't know why it is there but we should be able to override it with -
static (dmz2,dmz) 10.50.2.33 10.50.2.33  netmask 255.255.255.255
So if the ping didn't work can you add this to the pix and retest both with ping and connecting on the ports you want to use.
Jon
11 Replies 11
Jon Marshall
Tyler
Thanks for starting new thread. Here are the narrowed down configs -
ASA Version 8.2(5)
interface Ethernet0/0
description Internet
nameif outside
security-level 0
ip address 64.x.x.130 255.255.255.240
interface Ethernet0/1
description inside
nameif inside
security-level 100
ip address 10.50.2.1 255.255.255.0
interface Ethernet0/2
nameif dmz1
security-level 50
ip address 10.10.10.2 255.255.255.0
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list DMZ2IN extended permit tcp host 12.x.x.130 host 12.y.x.130 eq ftp
access-list DMZ2IN extended permit tcp host 12.x.x.130 host 12.y.x.130 eq ftp-data
access-list DMZ2IN extended permit tcp host 12.x.x.134 host 10.50.2.33 eq 1560
access-list DMZ2IN extended permit tcp host 12.x.x.134 host 10.50.2.32 eq 8888
access-list DMZ2IN extended permit ip any any
nat-control
global (outside) 1 interface
global (dmz1) 1 interface
nat (inside) 0 access-list NONAT
nat (inside) 1 10.50.2.0 255.255.255.0
static (inside,dmz1) tcp 10.50.2.32 8888 10.50.2.32 8888 netmask 255.255.255.255
static (inside,dmz1) tcp 10.50.2.33 1560 10.50.2.33 1560 netmask 255.255.255.255
access-group DMZ2IN in interface dmz1
route outside 0.0.0.0 0.0.0.0 64.x.x.129 1
route dmz1 12.x.x.134 255.255.255.255 10.10.10.1 1
PIX Version 7.0(6)
interface Ethernet0
nameif outside
security-level 0
ip address 12.xx.xx.2 255.255.255.248
interface Ethernet1
nameif dmz
security-level 50
ip address 12.x.x.129 255.255.255.224
interface Ethernet2
nameif dmz2
security-level 50
ip address 10.10.10.1 255.255.255.0
access-list temp_inside extended deny ip any host 89.163.182.25 log
access-list temp_inside extended permit ip any any
access-list dmz2_out extended permit ip host 12.x.x.134 host 10.50.2.32
access-list dmz2_out extended permit ip host 12.x.x.134 host 10.50.2.33
access-list dmz2_out extended permit ip any any
pager lines 24
logging enable
logging console debugging
logging monitor alerts
logging buffered debugging
logging trap notifications
mtu outside 1500
mtu dmz 1500
mtu dmz2 1500
icmp permit any outside
icmp permit any dmz
icmp permit any dmz2
no asdm history enable
arp timeout 14400
static (dmz2,dmz) 10.10.10.0 10.10.10.0 netmask 255.255.255.0
static (dmz,dmz2) 12.x.x.0 12.x.x.0 netmask 255.255.255.0
access-group temp_inside in interface dmz2
access-group dmz2_out out interface dmz2
route outside 0.0.0.0 0.0.0.0 12.xx.xx.1 1
route dmz2 10.50.2.0 255.255.255.0 10.10.10.2 1
timeout xlate 3:00:00
Jon
edited
Jon Marshall
On the ASA can you remove this -
add this -
static (inside,dmz1) 10.5.2.32 10.50.2.32 netmask 255.255.255.255
then -
clear xlate global 10.5.2.32
then -
add this line to DMZ2IN (make sure it is before the permit ip any any)
access-list DMZ2IN permit ip host 12.x.x.134 host 10.50.2.32
on the pix add this line to dmz2_out (again before the permit ip any any)
access-list permit ip host 12.x.x.134 host 10.50.2.32
Once all the above is done can you then ping from 12.x.x.134 to 10.50.2.32 and see -
1) do you get a response
2) do you see a hit cnt on the pix dmz2_out acl
3) do you see a hit on ASA DMZ2IN acl
Jon
Jon Marshall
Tyler
Jon
I've just now learned 10.50.2.32 is not up and running yet so I adjusted all the above for 10.50.2.33.
Ping is now working and I'm getting the response on port 1560 as I should. Looks like that static NAT did it. Going to button this down now to the specific ports and try again.
Tyler
Out of interest which static ? The one i asked you to change on the ASA or the one on the pix ?
Jon
This one in the PIX
I am curious about making this cleaner. Am I correct in thinking I can remove the stricken ones and and the bold one getting the same results?
static (dmz,outside) 12.x.x.130 12.x.x.130 netmask 255.255.255.255
static (dmz,outside) 12.x.x.131 12.x.x.131 netmask 255.255.255.255
static (dmz,outside) 12.x.x.142 12.x.x.142 netmask 255.255.255.255
static (dmz,outside) 12.x.x.144 12.x.x.144 netmask 255.255.255.255
static (dmz,outside) 12.x.x.138 12.x.x.138 netmask 255.255.255.255
static (dmz,outside) 12.x.x.150 12.x.x.150 netmask 255.255.255.255
static (dmz,outside) 12.x.x.156 12.x.x.156 netmask 255.255.255.255
static (dmz,outside) 12.x.x.135 12.x.x.135 netmask 255.255.255.255
static (dmz,outside) 12.x.x.140 12.x.x.140 netmask 255.255.255.255
static (dmz2,dmz) 10.50.2.0 10.50.2.0 netmask 255.255.255.0
static (dmz2,dmz) 10.50.2.32 10.50.2.32 netmask 255.255.255.255
Tyler
You should be able to do that with no effect on existing traffic although you would need to clear the xlate entries. I have been reluctant to suggest this because there is obviously other traffic going to the 12.x.x.x network from the ASA. Your entry in bold should account for that though. But you do need to be careful when changing things that you don't affect other traffic so you need to understand all the traffic flows. I have been trying to make as few changes as possible while we tried to troubleshoot this.
It was only after i cleared the configs that i noticed that pix entry. There is an awful lot in the configs such as acls and NAT entries, especially acls, that are simply not used either with NAT or assigned to any interface. It may be worth trying to clean all that up before you migrate everything onto the ASA.
So did it work ?
Edit - one thing i didn't check was whether the acls were referenced in the IPSEC config so it is worth checking that if you do decide to try and clean up the configs.
Edit 2 - If you do make those changes bear in mind you have a little less security than you had before especially with your permit ip any any statements in the acls. At the moment you have 2 static entries for 10.50.2.32 and 33 which allows connections from the pix to those hosts. The identity NAT statement does not allow any connections from the pix to any other 10.50.2.x hosts, it only allows traffic to be initiated from the 10.50.2.x hosts. if you configure a static for the whole 10.50.2.0/24 network then you are allowing connections from the pix to any 10.50.2.x hosts. This may or may not be a concern for you.
Jon
Will not get to try this out till next week.
I have actually removed the "ip any any" due to security. My thinking is create the static NAT on the PIX for the entire segment then lock things down on the ASA side when inbound. Though I could do it the other way around. To be honest haven't decided which way I am going to skin this cat. Given my plan is to consolidate to the ASA I will clean up with that in mind.
To the best of my limited expertise there are not active tunnels of any kind on the PIX. The tunnel now resides on the ASA so lots of the config on the PIX can be removed. Just hesitent to do so given my lack of experience.
Thank you again for all your help. It has taught me lots.
Tyler
No problem and thanks for getting back to me as i was wondering if it was working or not.
I think it should work if you were able to ping and i agree on removing the permit ip any any as this is too open.  A lot of the config on the pix doesn't seem to be needed. Even some of the NAT statements because the pix has a "same-security-traffic permit inter-interface" statement so you shouldn't need NAT between interfaces of the same security level. But because NAT has been used it's not as simple as just removing them without understanding what they are all doing.
I think what you are looking at is config that has sort of evolved so as you say there is probably a lot of the config that isn't actually needed but i understand your reluctance to make changes.
Jon
