how to determine which swich port be connected to a device with ipv6 ?
Sean Cheung
you can use IPV6 neighbor discovery for this. check below guide for commands. This will show connected neighbors if any. and use ARP table to identify any IPV4 user learnings.
show ipv6 nd
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/5_x/nx-os/unicast/configuration/guide/l3_cli_nxos/l3_ipv6.html#48831
rate and mark as answer if this resolved your concern
Good luck
KB
pman
switchport is a Layer 2 configuration.
There are two types of switchports: trunk or access.
port that configured with switchport (access or trunk) can pass both IPv6 and IPv4.
A Layer 2 port can transmit / receive both IPv4 and IPv6
To see where IPv6 device is connected:
show ipv6 neighbor binding
show ipv6 nd
show ipv6 neighbors
