How to elect SUP module as a active by manual configuration.
jsnoh0228
Hi, all.
I am struggling that if SUP engine can be configured as a active with manual configuration.
If I equipped two engines, SUP automatically decide to elect a active module. But I want to know which slot is higher between two slots.
And how can i control one SUP is active and other SUP is standby.
Mark Yeates
Level 7
Level 7
I don't believe there is a way to configure a specific supervisor to be "active" when the switch boots up. When the switch boots up whichever supervisor boots first typically will be the active supervisor.
HTH,
Mark
