How to export firmware from 3850 Switch to PC
unpnp17
Hi everyone,
i have an issue, i'd create stack building. however, i'm not sure same uptade between two switches so i'd export one with lastest ver on my pc.
How could i do?
thanks,
If the file in the USB then you make a sure copy from usb0: drive to flash: and run install command.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
9 Replies 9
Deepak Kumar
Can you share Show flash output.
Deepak Kumar
Deepak Kumar,
-#- --length-- ---------date/time--------- path
2 2097152 Mar 26 2018 03:27:10 +00:00 nvram_config
3 74369716 Nov 25 2015 19:18:06 +00:00 cat3k_caa-base.SPA.03.02.03.SE.pkg
4 5808828 Nov 25 2015 19:18:07 +00:00 cat3k_caa-drivers.SPA.03.02.03.SE.pkg
5 32496484 Nov 25 2015 19:18:06 +00:00 cat3k_caa-infra.SPA.03.02.03.SE.pkg
6 30418104 Nov 25 2015 19:18:06 +00:00 cat3k_caa-iosd-universalk9.SPA.150-1.EX3.pkg
7 16059104 Nov 25 2015 19:18:06 +00:00 cat3k_caa-platform.SPA.03.02.03.SE.pkg
8 64586444 Nov 25 2015 19:18:07 +00:00 cat3k_caa-wcm.SPA.10.0.120.0.pkg
9 1224 Nov 25 2015 19:18:17 +00:00 packages.conf
1311031296 bytes available (228544512 bytes used)
Reza Sharifi
3850s come with a USB port (usbflash0). So, you can transfer files from USB to flash or from flash to USB and load it to your PC.
thank you, by the way which patch i should export on my usb
There are several newer versions.  The latest (none Denali) version recommended by Cisco is                  cat3k_caa-universalk9.SPA.03.06.08.E.152-2.E8.bin
Thank you for your advice, i have one more issue. I've confused when i transfer that you send .bin file so that i have no idea to copy where ?
crashinfo: Copy to crashinfo: file system
flash: Copy to flash: file system
null: Copy to null: file system
nvram: Copy to nvram: file system
running-config Update (merge with) current system configuration
startup-config Copy to startup configuration
stby-nvram: Copy to stby-nvram: file system
stby-rcsf: Copy to stby-rcsf: file system
syslog: Copy to syslog: file system
system: Copy to system: file system
tmpsys: Copy to tmpsys: file system
usbflash0: Copy to usbflash0: file system
thank you
Deepak Kumar
Deepak Kumar,
You don't have .bin file on your switch flash so you have to download from Cisco website. As mention @Reza Sharifi recommended version is :cat3k_caa-universalk9.SPA.03.06.08.E.152-2.E8.bin
Deepak Kumar
Deepak Kumar,
Leo Laohoo
Go to the Cisco website and download the file from there.
