01-12-2021 08:26 AM
I was setting up a switch and unfortunately I can not login into my switch. I cant get in, I am stuck at the login.
Is there any way to reset that switch?
01-12-2021 08:29 AM
try - username: cisco, password: cisco
if not follow reset butting as mentioned in the document :
01-12-2021 08:32 AM
I already setup a user and password through cli, I do not know why I can not get in
01-12-2021 08:36 AM
make sure check the CAPs lock on something like that, make sure you type the password notepad and see is that what working ?
if you do not have one reset the device and setup a username and password.(do not write information to device,) test is this working ?
then write.
01-12-2021 08:41 AM
I tried with "cisco, cisco" but its not working, I looked at flash:/config.text and there was no user setup or password setup.
01-12-2021 08:45 AM
In your Web browser, enter the IP address 172.16.0.1. Enter the following default credentials: username: cisco, password: cisco and press Enter.
01-12-2021 08:56 AM
ok, so you only need to interrupt the boot sequence and then
switch: rename flash:config.text flash:config.text.old
then boot and it will bring you back to the factory settings
05-05-2022 10:53 AM
This absolutely works. Thanks!
09-17-2022 06:44 PM
How do I apply this reset? Is this a command line action? I am having a similar issue on a c1000-8p after exiting the GUI I can not get back in, reset to Zero-day, or even confirm the switch IP thought a browser.
10-04-2022 12:59 AM
interrupt boot sequnce and you will get to the boot loader. Then just delete or rename your current config.
02-03-2024 09:49 PM
Genius!
01-12-2021 09:53 AM
yes test and advise.
07-04-2021 09:12 AM
A mi también me pasa lo mismo, apago y enciendo el switch e ingreso en modo recuperación, en la flash me dice que no hay o no esta el archivo.
switch: dir
List of filesystems currently registered:
xmodem[0]: (read-only)
null[1]: (read-write)
vmap[3]: (read-only)
bs[4]: (read-only)
bsg[5]: (read-only)
flash[11]: (read-write)
switch: dir flash
unable to stat flash/: no such device
switch: dir flash/
unable to stat flash//: no such device
switch:
10-04-2022 12:58 AM
it is right there, try flash:
07-28-2023 10:12 AM
I am having this same issue
