setting up new FEX switches but po already exists on switches
robertkwild
hi all,
we have 2 7000's and obviously they have previously been set up on both switches as when i do on both switches
sh int po101
switch 1 has no members but switch 2 has 2 members ie ethernet ports assigned to this po say for ex 1/0/1 1/0/2
shall i just run on switch 2 as i dont want it configured on switch 2, i only want it on switch 1
default int 1/0/1,1/0/2
no po101
thanks,
rob
7 Replies 7
balaji.bandi
FEX in Dual home - means you connect both the nexus Switches for high availability
FEX in single home connect to only 1 Parent Switch
if that is your requirement yes you can connect to only 1 Switch.
But failure scenario - if that parent switch go down, the FEX go down too.
BB
Thanks I want to single home not dual home
Is it wise then to delete the po and flatten the ethernet ports for switch 2 as I only want to connect to switch 1 IE
Default int 1/0/1,1/0/2
No po101
Or can I leave the config on switch 2 but not plugged in switch 2, is that ok to do?
If the requirement only 1 switch, i remove other switch config, so if any other purpose can be used - for the complete and cleaness.
BB
another question, how come the FEX po is not trunked
Po103 -- connected 1 full a-10G --
how come its connected to vlan 1 but then when i change port eth103/1/1 to vlan 170 it works as when i plug in a pc on that port it works
as per OP you have 101 for FEX right ?
show interface port-channel 101 switchport  (this will show you all the VLAN) example :
Operational Mode: fex-fabric
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Allowed: 1-4094
Po103 you have created  as trunk - then all the vlan should allowed in the Trunk
For end port always default is VLAN1 - if you like to have access vlan 170- then you need to change access vlan 170.
BB
Ruben Cocheno
@robertkwild
I would dual home with FEXs if you have that capability, but in not mandatory.
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
so am i right in thinking that FEX all the trunks go down the native vlan ie 1 where as normally when you configure a port and you want it trunked it actaully says trunk instead of 1, thats why im confused?
