How to hide mac addresses using Cisco switches
Tomasz Hinz
I Lease fiber between two locations, My operator limiting number of MAC addresses to 8 macs. Is there any possibility using some feature available in the Cisco 3750 switches to (hide mac addresses) encapsulate traffic witch flowing via operator network ?
I need to send data between locations with 1Gb/s speed.
If 3750 switches can't do that, which models of switches 1 or 2U can do it. May Metro switches ?
Comel - Tomasz Hinz
********************************* Comel - Tomasz Hinz
Dale Miller
Quick question, can you use L3 as an option? Packet rewrite would limit it to the source and dest of the PT-to-PT interfaces? If not, you will want to tunnel it so encap would be the same for every packet. Looking into possible options.
Dale
