How to manage many cisco switch ?
rechard_hk
Dear All,
I would like to as you that i have swich 2960 (10Unit) and switch 3560 ( 3 unit) and router 2821 ( 1 unite) and AP( 10 unit).
So do you know software can manage all those product? Like monitor switch up or down, manage configure, check performance..........
Best Regards,
Rechard
8 Replies 8
Reza Sharifi
To get the best response for your question, you should try moving your post to the Network Management sub-forum
Dear Reza,
thanks you.
Best Regards,
Rechard
Hi Rechard,
LMS might help you.Or try SNMP.
You can use NAGIOS, simple and a good product for such purposes. (IT uses SNMP to get the information from Cisco)
Solarwinds toools might be an alternative.
BR,
Milan
Simple and effective tools are Whats Up Gold and Solarwinds.
You can also try Cisco's NMS: Ciscoworks.
Smitesh
    Cisco Network Assistant , its a free network management download here on the cisco site.  Doa search on the main cisco page.
jodi.bart
Hi Rechard,
I work for SolarWinds and recommend that you check out SolarWinds Network Performance Monitor (NPM) -- it's our flagship product and will help you detect, diagnose, and resolve network problems quickly. Here's a link: http://www.solarwinds.com/products/network-management/network-monitoring.aspx.
Best,
Jodi Bart
