How to monitor network bandwidth usage
cisco_himg
Can someone tell me what to use to monitor network bandwidth for my company?
Does Cisco make a program or GUI that allows me to monitor?
THank you!
8 Replies 8
Giuseppe Larosa
Hello Dustin,
a very good free tool is MRTG
http://oss.oetiker.ch/mrtg/
We use it and allow to produce nice graphs published as web pages.
It is widely used and it has 10 years of history.
Hope to help
Giuseppe
thank you. this looks a little difficult to install. is it?
no, its not. you can install it on unix and windows boxes as well. it all depends on you.
another tool is 'rrdtool' which is also being developed by the person who developed mrtg. a front-end of this one is 'cacti'.
thanks !
Is MRTG a licensed software.
Its free as long as you do not break the licencing rules.
Here is the link to explain you further and to download/install software.
http://www.gnu.org/copyleft/gpl.html
Hope this helps.....
Shaheen
Could you also please tell the difference between PRTG and MRTG.
Google friend took me to this link which explain the difference between both. In some cases PRTG commercial licence is required.
http://www.paessler.com/blog/2006/09/25/prtg-traffic-grapher/comparing-prtg-traffic-grapher-with-mrtg/
Hope this helps....
Shaheen
just make sure you use snmp v2 and higher as v1 cannot increment gigabit rates and will give you false data. It will work with FA but not Gig.
