how to rate limit traffic
network770
I the following setup:
switch1 -->
                  switch3 --> C2800 --> ASA --> Internet
switch2 -->
the switches are C3560's.
I would like to limit some ports on all 3560's to 2MG to the Internet (both ways) and drop all traffic surpassing that limit.
Do I need to configure only the switches? only the router? only the firewall? or all?
how would the configuration look like?
Another thing, if I rate limit a few ports to 2MG, is there a need for queuing on the router?
I would like to simplify the config as much as possible as I am not a qos expert.
Robert W. Rogier
Ronni,
    Is there a common theme to the traffic you want to rate  limit?  Ideally, if you can keep all these people into the same subnet,  you can match on that in an ACL and place your rate limit on the  router.  Also, remember if you have deployed VoIP, you'll need to do  queuing across the entire design to allow VoIP to work correctly.  I  would try to put the limits on the router itself.  If you try to put all  the rate limits on router ports, you will just make your life more  miserable.
Robert W. Rogier
CSE - TAC UCC
Robert W. Rogier
Technical Consulting Engineer – Contact Center Enterprise
E2E Lead | Subject Matter Expert – ECE, CCMP, CCDM
Phone: +1 919 574 5993
Email: rorogier@cisco.com
Business Hours: 8AM to 5PM ET
