how to recover a Catalyst9300-24P from ROMMON
rifasbabu
I think flash is corrupt, Anyone please help me to install IOS
I have tried below but wont work
switch: dir usbflash0:
Size Attributes Name
32768 drw- System Volume Information
892195673 -rw- cat9k_iosxe.17.03.01.SPA.bin
switch: emergency-install usbflash0:\cat9k_iosxe.17.03.01.SPA.bin
WARNING: The system partition (bootflash:) will be erased during the system recovery install process.
Are you sure you want to proceed? [y] y/n [n]: y
Starting system recovery (usbflash0:cat9k_iosxe.17.03.01.SPA.bin) ...
boot: attempting to boot from [sda9:cat9k-recovery.SSA.bin]
boot: reading file cat9k-recovery.SSA.bin
PLATFORM_TYPE C9300 speed 9600
Booting Recovery Image 16.6.1
Initiating Emergency Installation of bundle usbflash0:cat9k_iosxe.17.03.01.SPA.bin
Emergency Install failed - bundle usbflash0:cat9k_iosxe.17.03.01.SPA.bin does not exist
Will reboot now
Initializing Hardware......
System Bootstrap, Version 17.12.1r, RELEASE SOFTWARE (P)
Compiled Mon 04/24/2023 22:21:00.36 by rel
Current ROMMON image : Primary
Last reset cause : SoftwareReload
C9300-24P platform with 8388608 Kbytes of main memory
6 Replies 6
marce1000
  - FYI : https://community.cisco.com/t5/switching/any-idea-on-how-to-recover-a-catalyst9300-from-rommon/m-p/3405757/highlight/true#M417523
 M.
balaji.bandi
Instead of this why not boot from USB
switch:boot usbflash0:\cat9k_iosxe.17.03.01.SPA.bin
example :
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/217607-troubleshoot-and-recover-catalyst-9000-s.html#toc-hId-1127156612
BB
I have tried boot from USB Flash but fails
switch: boot usbflash0:\cat9k_iosxe.17.03.01.SPA.bin
boot: attempting to boot from [usbflash0:cat9k_iosxe.17.03.01.SPA.bin]
boot: reading file cat9k_iosxe.17.03.01.SPA.bin
MM [1] MCU version 191 sw ver 228
MM [2] MCU version 191 sw ver 228
MCU UPGRADE IN PROGRESS... PLEASE DO NOT POWER CYCLE!!
Front-end Microcode IMG MGR: found 4 microcode images for 1 device.
Image for front-end 0: /tmp/microcode_update/front_end/fe_type_6_0 update needed: no
Image for front-end 0: /tmp/microcode_update/front_end/fe_type_6_1 update needed: yes
Image for front-end 0: /tmp/microcode_update/front_end/fe_type_6_2 update needed: yes
Image for front-end 0: /tmp/microcode_update/front_end/fe_type_6_3 update needed: no
Front-end Microcode IMG MGR: Preparing to program device microcode...
Front-end Microcode IMG MGR: Preparing to program device[0], index=0 ...594412 bytes.... Skipped[0].
Front-end Microcode IMG MGR: Preparing to program device[0], index=1 ...440976 bytes.
Front-end Microcode IMG MGR: Programming device 0...rwRrrrrrrw..0%..................................................................................10%..................................................................................20%.................................................................................30%..................................................................................40%..................................................................................50%..................................................................................60%.................................................................................70%..................................................................................80%..................................................................................90%.................................................................................100%
Front-end Microcode IMG MGR: Preparing to program device[0], index=2 ...24506 bytes.
Front-end Microcode IMG MGR: Programming device 0...rrrrrrw..0%....10%....20%......30%...40%....50%......60%....70%.....80%....90%....100%w
Wating for MCU to come up .....Rr!
Front-end Microcode IMG MGR: Microcode programming complete for device 0.
Front-end Microcode IMG MGR: Preparing to program device[0], index=3 ...90974 bytes.... Skipped[3].
Front-end Microcode IMG MGR: Microcode programming complete in 310 seconds
MCU UPGRADE COMPLETED!!...
Both links down, not waiting for other switches
Switch number is 1
Nov 7 07:26:50.706: %PMAN-3-PROCHOLDDOWN: R0/0: The process cmand has been helddown (rc 139)
Nov 7 07:26:50.795: %PMAN-0-PROCFAILCRIT: R0/0: pvp: A critical process cmand has failed (rc 139)
Nov 7 07:26:50.851: %PMAN-3-RELOAD_RP: R0/0: pvp: Reloading: Switch will be reloaded
Chassis 1 reloading, reason - Non participant detected
Nov 7 07:26:51.559: %PMAN-5-EXITACTION: F0/0: pvp: Process manager is exiting: reload fp action requested
Nov 7 07:26:52.561: %PMAN-5-EXITACTION: R0/0: pvp: Process manager is exiting: Critical process cmand fault on rp_0_0 (rc=139)
Nov 7 07:26:56.211: %PMAN-3-PROCESS_NOTIFICATION: R0/0: pvp: System report /crashinfo/RP_0-system-report_local_20241107-072652-Universal.tar.gz (size: 14481 KB) generated
boot: attempting to boot from [flash:packages.conf]
boot: reading file packages.conf
Fatal error: This version of the software does not support this model of the switch(0x7057). Please check and use the versions where the support is available.
Nov 7 07:30:03.799 RP0/0: %PMAN-3-PROCHOLDDOWN: The process platform_mgr has been helddown (rc 134)
Nov 7 07:30:04.613 RP0/0: %PMAN-0-PROCFAILCRIT: A critical process platform_mgr has failed (rc 134)
Nov 7 07:30:04.655 RP0/0: %PMAN-3-RELOAD_RP: Reloading: Switch will be reloaded
Try a different version, like 17.12.4.
Leo Laohoo
I "think" the firmware file is missing from the USB flash drive (or the filename is incorrect).
The file is there in USB Flash drive and name is correct. I have downloaded other version but the result is same.
