how to remove Redundancy on 6506 sup2t
Steve Chapman
I currently have a test box with 2 sup2t in redundancy sso mode.  How do i remove the redundancy?  I need to split these up to use in other boxes as standalone.
2 Accepted Solutions
Mark Malone
Just take out the standby supervisor , leave the active one
remove the redundancy config like below , should be in global config
redundancy
main-cpu
auto-sync running-config
mode sso
to check whos active supervisor in teh chassis
show redundancy
Thats it really
Scott Hodgdon
Steve,
SSO  Redundancy is enabled by default when you insert a 2nd supervisor into a chassis. Once you remove the 2nd supervisor to use elsewhere, the system will know there is no SSO since it will not sense the presence of a 2nd supervisor.
Cheers,
Scott
5 Replies 5
Mark Malone
redundancy
main-cpu
mode sso
show redundancy
Thats it really
I have tired to remove in running config the no command does not work.  I then uploaded a new configuration without redundancy to startup and reloaded still the redundancy command comes back.
Scott Hodgdon
Steve,
Cheers,
Scott
I have removed the 2nd sup. rebooted several times and even upgraded the IOS and it still comes up with redundancy enabled.
I looked at other 6509 and the redundancy command is hard coded even if you not using it.  so I all good thanks.
