How to remove vlan and subinterface
mahesh-gohil
Der all,
i have cisco 7613 router
i want to remove following config from configuration
interface Vlan2
no ip address
interface Vlan200
no ip address
and
sh int description
Interface Status Protocol Description
Vl1 admin down down
Vl2 down down
Vl200 down down
Gi1/0/0 down down
Gi1/0/1 up up
Gi1/0/1.200 deleted down
Gi1/0/1.300 deleted down
Pl. guide
is there any method to remove all config by single command
6 Replies 6
nambi_gct
You can use "no interface range vlan 12 , vlan 200".You can also consider "configure replace" command in some situations.BUT PLEASE MAKE SURE THAT YOU TRY OUT THESE COMMANDS IN LAB ENVIRONMENT BEFORE USING THEM IN PRODUCTION NETWORK.
In addition, to completely remove the interfaces shown as deleted you'll have to reload the router.
HTH,
Mohammed Mahmoud.
and pl. tell me how to set router to its default config.
means whatever config change I have done in lab setup ..i want to come back to its default startup config
if you wanted to make your router to factory default settings, then type "erase startup-config" this will erase all the configurations on the router & brings you to the factory default settings.
when i am trying this command on 3750 switch it show
#no interface range vlan 100
% "No" version of this command not supported for range 1.
% Command will not be applied to any of the ranges.
how can I remove vlan from this switch
regards
Mahesh
Use no interface vlan 100, and also remove the VLAN itself if not needed either via the vlan database or global configuration mode, and to completely reset the switch to the default setting, if the switch was a VTP server or client then you'll also have to delete the vlan.dat file from the flash.
HTH,
Mohammed Mahmoud.
