[How to resolve] CRC errors
Josiah Inubio
Guys,
I see many crc errors on the interface, how will I face and resolve this issue? Is there any initial fault isolation that I must do? Sometimes crc errors occur on the GigE interface. Thanks.
FastEthernet0/13 is up, line protocol is up
  Hardware is Fast Ethernet, address is 0004.4d27.66cd (bia 0004.4d27.66cd)
  Description: EDL-P-Box-NO-4
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 250/255, txload 1/255, rxload 1/255
  Keepalive not set
  Auto-duplex (Full), Auto Speed (100), 100BaseTX/FX
  Last input 18:52:43, output 00:00:01, output hang never
  Queueing strategy: fifo
  Output queue 0/40, 0 drops; input queue 0/75, 0 drops
  5 minute input rate 12000 bits/sec, 6 packets/sec
  5 minute output rate 24000 bits/sec, 6 packets/sec
     14488019 packets input, 2783320210 bytes
     Received 345346 broadcasts, 0 runts, 0 giants, 0 throttles
     261028 input errors, 259429 CRC, 1599 frame, 0 overrun, 0 ignored
     0 watchdog, 84207 multicast
     19658279 packets output, 3529106068 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 lost carrier, 0 no carrier
17 Replies 17
Not sure.
CRC, as what Inayath is saying, is a layer 1 issue.  Happens when your layer 1 is "dirty".  In your case, it's caused by a faulty cable.  If you have switches that I've mentioned, then you can run a test called TDR.
We have these on our transmission facilities but its OTDR (Optical). Also some of our Field Engineers use fluke networks cable analyzer.
OTDR is fibre optic.  Get your FE to do a TDR to determine where the faulty pair is located and replace if found.
