How to resolve Native Vlan Mismatch on two switch?
Elrick Landon
Hi to all
I have two switch, switch A (C9300) and switch B (C3850).
Switch A has three vlan: vlan 2000, 3000 and 4000.
Switch B has one vlan: vlan 1 (default)
Switch A is displaying log with:
CDP-4-NATIVE_VLAN_MISMATCH : Native VLAN mismatch discovered on GigabitEthernetX/X/X, with C3850#1 GigabitEthernetX/X/X
I precise that i use port-Based VLAN with no trunk (trunk is not usefull for my meaning).
All is working fine expect this message
Does this message is important ? How can i fix it?
Does it is better to define VLAN1 as VLAN2000 on Switch B?
Many thanks for your help.
18 Replies 18
Thanks for the reply.  They are plugged into a FPR1010 all are switchports on the firepower as well.  The firepower doesn't designate it's ports with three characters "1/0/2", just 2 characters "1/2" so it isn't complaining about that, it has to be the switch itself.  fpr.png
spunner
I just enabled "protected port" we'll see if that does anything...besides break my network
That seemed to do the trick!  Not sure how you do that in CLI, but it fixed the errors and didn't break my network.
Thanks for the update. Glad it seems to be working.
Rick
