How to see router serial number using command
holunking
Dear all,
As title, which command can help me?
Thx.
mahesh-gohil
U can use "show inventory" to view router serial number
to view modules serial no u can use "show diag" command
Hi Friend,
THe ISR router serial numbers can be viewed with the help of "Show inventory" command.
Old routers like the 2621 if running the new code shows the processor board number with the "show inventory" command (can be verified with show version)
To view serial numbers for catalyst switches, you can use "show version"
HTH, rate if it does
Narayan
