How to set LAN speeds to 200mbps
PIKEYMIKEY
A customers router speed has been increased to 200mbps but their LAN speeds remain 100mbps.
How can I either set individual ports to a max of 200mbps speed or set all ports to a max of 200mbps?
balaji.bandi
What kind of device is this,  post show interface information.
if this is fast ethernet, 100MB is Max.
BB
Leo Laohoo
What is the model of the router?
pieterh
"A customers router speed has been increased to 200mbps"
This most likely means the customers ISP has increased the bandwith of the internet connection .
most of the time this means bandwith limiting is increased to 200Mbps.
the ISP device should offer a Gbps interface and you need the customers LAN device also with 1Gbps interface
sometimes a provider calls 100Mbps send + 100Mbps receive, 200Mbps but this is not actually correct
You need to confirm with the ISP that this is 200Mbps in one-direction (receive or send)!
