How to set up guest wifi network on 1200 series APs with disclaimer web portal?
spookjay1
I've been thinking about this one for awhile. I want to set up a guest wifi network without any security (AES / TKIP) that allows guests to connect. Ideally, their web browser would be redirected to a web portal containing legal disclaimers, and they would need to accept the terms and conditions to use the guest wifi. I would also like to have them be required to visit the web portal again every 8 hours after that to accept the terms and conditions again.
I have a Cisco 1240AG access point already. What else do I need to make this work?
mmoulson1
Level 4
Level 4
I don't believe you can do this just with an AP running in autonomous mode you would need to have a WLC to configure the splash page.
Have a look here:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0/configuration/guide/c70/c70users.html#wp1049273
Alternatively you can use software running on a PC/Server. Something like http://www.antamedia.com/hotspot/
Hope that helps!
Matty
mmoulson1
Level 4
Level 4
Have a look here:
Hope that helps!
Matty
