How to setup two LAN on C2960XR Switch with Port-Based VLAN ?
Elrick Landon
Hi to all,
I'm looking to create two LAN isolated on a single physical switch with port-based VLAN (untagged).
One port from each VLAN will be plugged to switch (link in yellow and green), see picture below.
VLAN 2000, name = GUEST, subnet = 172.16.1/24
VLAN 3000, name = WIFI, subnet = 10.0.1/24
I need to be sure that both VLAN cannot communicate to each one for security reason.
Currently, my switch has only VLAN1, setup is like this :
Using 3379 out of 524288 bytes
! Last configuration change at 13:25:47 CET Sat Feb 16 2019
! NVRAM config last updated at 13:26:02 CET Sat Feb 16 2019
version 15.2
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname C2960XR#1
boot-start-marker
boot-end-marker
enable secret 5 XXXXXXXXXXXXXXX
enable password 7 XXXXXXXXXXXXXXXXX
username Cisco privilege 15 secret 5 XXXXXXXXXXXXXXXXXXXXXXXXXXXX.
no aaa new-model
clock timezone CET 1 0
clock summer-time CET recurring last Sun Mar 1:00 last Sun Oct 1:00
switch 1 provision ws-c2960xr-48lpd-i
system mtu routing 1500
crypto pki trustpoint TP-self-signed-XXXXXXXXXXXXX
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-XXXXXXXXXXXX
 revocation-check none
 rsakeypair TP-self-signed-XXXXXXXXXXXXXXXX
crypto pki certificate chain TP-self-signed-XXXXXXXXXXXXXX
 certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
spanning-tree mode pvst
interface Bluetooth0
 no ip address
 shutdown
 downshift disable
interface FastEthernet0
 no ip address
 shutdown
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface TenGigabitEthernet1/0/1
interface TenGigabitEthernet1/0/2
interface Vlan1
 ip address 192.168.1.233 255.255.255.0
ip default-gateway 192.168.1.1
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
no vstack
line con 0
 password 7 XXXXXXXXXXXXXXXXXX
 login
line vty 0 4
 login
line vty 5 15
 login
ntp server ntp.deuza.net
ntp server pool.ntp.org
end
I think that i need to use these command, do you confirm that is correct ? Is it enough ?
configure
#vlan 2000
#name VLAN GUEST
#no shutdown
#exit
configure
#vlan 3000
#name VLAN WIFI
#no shutdown
#exit
configure
#interface vlan 2000
#ip address 172.16.1.254 255.255.255.0
#no shut
#exit
configure
#interface vlan 3000
#ip address 10.0.1.254 255.255.255.0
#no shut
#exit
configure
#interface range Gi1/0/3-48,Te1/1/1,Te1/1/2
#switchport mode access
#switchport access vlan 2000
#exit
#interface range Gi1/0/1, Gi1/0/2,Te1/0/1,Te1/0/2
#switchport access vlan 3000
#exit
Best Regards,
Elrick
7 Replies 7
balaji.bandi
yes that is correct, make sure your uplink side allow these VLAN (in the port-channel or trunk) towards FW side.
BB
AndreaTornaghi
Yes, it's correct man. No shutdown on VLAN creation is not needed.
Hello
@Elrick Landon wrote:
Hi to all,
On the svi of each vlan you can apply a RACL to negate access between the vlans
Example:
access-list 100 deny ip 10.0.1.0 0.0.0.255 any
access-list 100 deny icmp 10.1.0 0.0.0.255 any echo-reply
access-list 100 permit ip any any
access-list 100 permit icmp any any
int vlan 2000
ip access-group 100 out
access-list 101 deny ip 172.16.10 0.0.0.255 any
access-list 101 deny icmp 172.16.10 0.0.0.255 any  echo-reply
access-list 101 permit ip any any
access-list 101 permit icmp any any
int vlan 3000
ip access-group 101 out
Also highly recommend you check the internal vlan usage (show vlan internal usage)  of the switch prior to designing and allowing any extended vlans, so you dont by mistake create a SVI and vlan that is being used internally by the switch.
Lasty note extended vlans can only be configured in the vlan database,stored to the vlan.dat file and propagated throughout the vlan estate via version 3 of vtp  vtp version 1/2 can be used but each switch would require to be in vtp transparent mode and saved to the running config.
Kind Regards
Paul
I was thinking that two VLANs created in this way are completely isolated, like if I have two physical switches, meaning that it was impossible to have communication between VLAN 2000 and VLAN 3000, is that right ?
Does RACL purpose is just a safeguard method in case of hack or something like this ?
Regarding the VLAN1, it seems to me that it is impossible to delete it (by design), for security reasons, i need to tack care that it is not affected on port, is that right? or i have something special to do to 'disable' it ?
Hello
You absolutely correct, Having separate vlans on separate switches would be applicable, Initially looking your topology I saw two Switch Virtual Interfaces (SVI) on one switch and my assumption was this switch would be performing the inter-vlan routing but after looking again at your topology that doesnt seem the case as the FW looks like it would be doing that correct-  so apologies!
I see now also there will be separate links into the FW from this switch for either vlan so you could go even as far as putting the guest vlan it own VRF or DMZ.
One of it uses on a L3 switch can be to deny inter-vlan communication between vlans like the example I previously posted
From a L2 perspective you cannot delete, suspend or shutdown vlan 1 but at a l3 perspective it doesn't have to have an ip address associated to it and its interface can be shutdown
Kind Regards
Paul
Yes, but by default, two vlan with port based different cannot communicate right ?
My switch is 2960XR (L3), how can i shutdown vlan 1 interface from CLI please ?
Best Regards.
Hello
Apologies i missed your reply-
Correct they cannot unless some routing is involved
conf t
int vlan 1
shutdown
Kind Regards
Paul
