How to stack 2 3750 switches?
gnaveen
I have seen lot of documentations as how to stack 2 3750s switches.
I am looking for a step-by-step instructions on how to stack 2 3750 switches.
Really, appreciate if someone who has done it before and have hands-on experience (in lab or production environement) can direct me.
NG
You will not see line (with priority) when doing "sh run". But some one has done it
manually. I think, you can do it either in config mode and by setting "SWITCH_PRIORITY" environment variable.
12 Replies 12
Jayakrishna Mada
Hi Naveen,
Not sure if had a look at this document but take a look at this link and see if helps:
Leo Laohoo
Read the documents posted above.  If you are still confused, here's the quick-n-dirty way:
1.  Power up the switch master (ONLY!);
2.   Attach the stacking cable to the rest of the members;
3.  Power up the members ONE-AT-A-TIME and based on the order of your choice.
Example, if switch 2 is the 2nd switch, then power this switch after the master has been powered up and stacking cable has been applied.  This is followed by switch 3, switch 4, etc.
Rules-of-the-Thumb:
1.  Ensure all switches are running the same IOS version, same Feature Set (example IP Base);
2.  Once all switches are up, ensure you enable "switch n priority XX";
Thanks I was able to access the link.
I am not able to access the link.
Attached the document..
JayaKrishna
Wassim Aouadi
Level 4
Level 4
I did this scenario one month ago.
1. upgrade the new switch's IOS to match the same as the actual one (let's call it Master)
2. I shut down Master,
3. connected the new switch through its Stack cable,
4. boot Master, wait a few minutes and boot the new switch.
At this point, most of the configuration is synchronized between the two switches (vlans, etherchannel port, STP...). I had to manually configure switch ports.
Regarding stack master election and switch priority, I didn't change anything. But you should check for your gear.
Hope it helped.
Forum Tips: 1. Paste images inline - don't attach. 2. If you find a post helpful, please give it a thumbs up or mark it as a correct solution.
I am not sure if we need to boot the master?
I have these 3 switches stacked together, where SW01 is the Master.
SW01 : Stack 1 <--> Stack 2 : SW02
SW02 : Stack 1 <--> Stack 2 : SW05
SW05 : Stack 1 <--> Stack 2 : SW02
Now, I want to add SW06 to this stack
SW05 : Stack 1 <--> Stack 2 : SW06
SW06 : Stack 1 <--> Stack 2 : SW01
- Change the switch priority of SW06 to 1.
   switch 6 provision ws-c3750g-48ps
   switch 6 priority 1
- Make sure that you redo the connections, dis-connect and connect the stack cables
SW06 : Stack 2 <--> Stack 1 : SW05
- Power on the newly added switch.
This I plan on doing in the production, so please let me know if I am missing any steps here or I am doing something wrong.
-NG
Anyone?
show switch detail
                                               Current
Switch#  Role      Mac Address     Priority     State
*1       Master    0014.f2bc.6b00     15        Ready
2       Member    0019.e888.2600     10        Ready
5       Member    0016.4773.3780     1         Ready
I added switch 5 to the stack. But, when I looked at the "show switch detail"
command I see that switch 1 and 2 have priority configured on it.
But, in the config I have not configured any "switch 1 priority 15" and
"switch 2 priority 10" commands on the switch.
Where is the switch picking the priority from?
The default priority for the switch is 1.  So, some one has changed switch-1 (master) priority to 15 and switch-2 to 10
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml#stack3
You can configure switch priority by issuing this command.
switch priority
A higher priority value for a stack member increases its likelihood to be elected stack master and to retain its stack member number. The priority value can be 1 to 15. The default priority value is 1.
Do "show switch detail" to find which switch you need to change the priority.
show switch detail
                                               Current
5       Member    0019.e888.2600     12        Ready
7       Member    0016.4773.3780     10         Ready
switch 5 priority 12
switch 7 priority 10
Remember, that you will not see the switch priority command in the running config. These are written to system environment variables which you can I think grab once you are in ROMMON mode.
shubhamkumarhcl
http://www.ccnaccnplinux.com/2015/01/switch-stack-configuration.html
if You visit i am sure you will get useful information
