how to troublshoot etherchannel LACP on a WS-C3850-24P-S on 16.12.9
dbov68
We have a switch 3850 in a remote office to connect to a Dell Server. we wanted to deploy the same as other remote offices.
I try to find why the etherchannel on the WS-C3850-24P-S is not working on port G 1/0/1.
Saddly I did not found the configuration guide for the IOS 16.12.9 for my device 3850.
On an other remote office, I have the same configuration, that is working
My colleague tells me, from the Dell server he sees the the both links active
Thanks ofr your help
Daniel
the configuration:
interface GigabitEthernet1/0/1
switchport access vlan 111
switchport mode access
channel-group 1 mode active
end
interface GigabitEthernet1/0/16
end
interface Port-channel1
end
Interface status and Etherchannel:
ntrvg01#sh int g 1/0/1
GigabitEthernet1/0/1 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is f078.1635.4481 (bia f078.1635.4481)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
input flow-control is on, output flow-control is unsupported
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
Output 0 broadcasts (0 multicasts)
0 output errors, 0 collisions, 6 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
ntrvg01#sh int g 1/0/16
GigabitEthernet1/0/16 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is f078.1635.4490 (bia f078.1635.4490)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
Last input 00:00:03, output 00:00:00, output hang never
5 minute input rate 22000 bits/sec, 2 packets/sec
5 minute output rate 11000 bits/sec, 4 packets/sec
239242 packets input, 225884035 bytes, 0 no buffer
Received 2041 broadcasts (1971 multicasts)
0 watchdog, 1971 multicast, 0 pause input
402864 packets output, 73359946 bytes, 0 underruns
Output 71214 broadcasts (0 multicasts)
0 output errors, 0 collisions, 2 interface resets
ntrvg01#sh etherchannel detail
Channel-group listing:
Group: 1
Group state = L2
Ports: 2 Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol: LACP
Minimum Links: 0
Ports in the group:
Port: Gi1/0/1
Port state = Down Not-in-Bndl
Channel group = 1 Mode = Active Gcchange = -
Port-channel = null GC = - Pseudo port-channel = Po1
Port index = 0 Load = 0x00 Protocol = LACP
Flags: S - Device is sending Slow LACPDUs F - Device is sending fast LACPDUs.
A - Device is in active mode. P - Device is in passive mode.
Local information:
LACP port Admin Oper Port Port
Port Flags State Priority Key Key Number State
Gi1/0/1 SA down 32768 0x1 0x0 0x102 0x4D
Age of the port in the current state: 0d:01h:00m:40s
Port: Gi1/0/16
Port state = Up Mstr Assoc In-Bndl
Port-channel = Po1 GC = - Pseudo port-channel = Po1
Local information:
Gi1/0/16 SA bndl 32768 0x1 0x1 0x111 0x3D
Partner's information:
Port Flags Priority Dev ID Age key Key Number State
Gi1/0/16 FA 0 cc96.e5f8.bfb0 6s 0x0 0x0 0x1 0x3F
Age of the port in the current state: 0d:06h:03m:46s
Port-channels in the group:
Port-channel: Po1 (Primary Aggregator)
Age of the Port-channel = 0d:06h:05m:43s
Logical slot/port = 12/1 Number of ports = 1
HotStandBy port = null
Port state = Port-channel Ag-Inuse
Protocol = LACP
Port security = Disabled
Ports in the Port-channel:
Index Load Port EC state No of bits
0 00 Gi1/0/16 Active 0
Time since last port bundled: 0d:06h:03m:46s Gi1/0/16
ntrvg01#
ntrvg01#show cable-diagnostics tdr interface G 1/0/1
TDR test last run on: February 16 13:29:27
Interface Speed Local pair Pair length Remote pair Pair status
Gi1/0/1 auto Pair A 16 +/- 1 meters N/A Open
Pair B 16 +/- 1 meters N/A Open
Pair C 16 +/- 1 meters N/A Open
Pair D 17 +/- 1 meters N/A Open
ntrvg01#show cable-diagnostics tdr interface G 1/0/16
TDR test last run on: February 16 13:30:11
Gi1/0/16 1000M Pair A 5 +/- 10 meters Pair A Normal
Pair B 5 +/- 10 meters Pair B Normal
Pair C 5 +/- 10 meters Pair C Normal
Pair D 5 +/- 10 meters Pair D Normal
ntrvg01#
SHUT-NO SHUT:
000787: Feb 16 17:45:23.627: LACP: lacp_insert_partner_cd_inhibitor: didn't change sync flag.
000788: Feb 16 2024 17:45:23.734 CET: %LINK-5-CHANGED: Interface GigabitEthernet1/0/1, changed state to administratively down
000789: Feb 16 17:45:23.734: FEC: lacp_switch_get_prot_enabled: returning [2] for Gi1/0/1
000790: Feb 16 17:45:24.624: LACP: lacp_insert_partner_cd_inhibitor: didn't change sync flag.
000791: Feb 16 2024 17:45:25.198 CET: %SYS-5-CONFIG_I: Configured from console by xxx on vty0 (xxx)
000792: Feb 16 17:45:25.496: LACP: lacp_insert_partner_cd_inhibitor: didn't change sync flag.
000793: Feb 16 17:45:26.115: FEC: pagp_switch_groupinfo - group 1
000794: Feb 16 2024 17:45:26.185 CET: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to down
000795: Feb 16 17:45:26.185: FEC: lacp_switch_get_prot_enabled: returning [2] for Gi1/0/1
000796: Feb 16 17:45:26.382: LACP: lacp_insert_partner_cd_inhibitor: didn't change sync flag.
000797: Feb 16 17:45:27.335: LACP: lacp_insert_partner_cd_inhibitor: didn't change sync flag.
5 Replies 5
balaji.bandi
as for switch concern not connected ? Does Dell Server support LACP ?
Looks for me Physical issue, try move the Link from 1/0/16 to 1/0/1 and see if that port come up - then you know what need to done next ?
BB
Leo Laohoo
TDR sees a 16 metre cable but it is flapping in the wind.  The far-end is not connected to anything.
dbov68
thanks for the help
the solution was found by a colleague, the other port was was on G1/0/19, not on the G1/0/1. I was searching to far. Just shut the port on the Dell, identify the port going dow and reconfigure.. well done
Is the configuration guide for IOS-XE 16.12.09 existing online ? I did not found it
regards
Daniel
what configuration guide ?
BB
Software Configuration Guide, Cisco IOS XE Gibraltar 16.12.x (Catalyst 3850 Switches) - Cisco
once upon the time, its was a full pdf book, it was easy to download and seach
The seach on the bar seem not working with LACP
If you open Contents, Layer, Configuring EtherChannels, the magic happens
If you gave the link for the full pdf, it will be great
Best regards
Daniel
