HSRP backup taking two minutes
majed.balsharaf
   I configure HSRP on Router 2951 as a primary router, and Router 2811 as backup router. But when I am switching off my Primary router the backup router is  taking 2 mins to take over form primary router.
Primary Router
Wan interface g0/1
Lan interface g0/0
Backup Router
Wan interface f0/1
Lan interface f0/0
Kind Regards
Reza Sharifi
Can you post configs form both routers?
I agree that seeing the configurations would be a good starting place. I believe that it may also be helpful to see some information about how the routers are connected. Are the routers connected to switches? to the same switch? to multiple switches?
Can we see the configuration of the switch ports where the routers are connected and the output of show interface for these ports?
Rick
Rick
majed.balsharaf
Primary Router:
LAN Interface
interface GigabitEthernet0/0
ip address x.x.x.3 255.255.255.0
ip accounting output-packets
ip flow ingress
standby 1 ip 10.100.16.1
standby 1 priority 200
standby 1 preempt
duplex auto
speed auto
WAN interface
interface GigabitEthernet0/1
ip address x.x.x.162 255.255.255.252
duplex auto
speed auto
Back up router:
LAN
interface FastEthernet0/0
ip address x.x.x.4 255.255.255.0
ip route-cache flow
duplex auto
speed auto
WAN
interface FastEthernet0/1
ip address x.x.x.74 255.255.255.252
duplex auto
speed auto
Both are connected through 2960 switch with portfast and in vlan 100
Hi Majed,
You can have the settings like the below and check if that helps.
Primary Router
standby 1 timers msec 500 2
standby 1 preempt delay minimum 60
standby 1 track 40
standby 1 track 40
Secondary Router
standby 1 priority 150
standby 1 preempt
Do make an alternate arrangements as per your network structure and try it should go well.
Please do rate if the given information helps.
By
Karthik
