HSRP Interface Tracking
limtohsoon
Level 7
Level 7
Hi Sir,
I'm configuring HSRP interface tracking feature. I use the track object method, as follows:
track 1 interface s0/0/0 line-protocol
interface FastEthernet0/0
standby 1 track 1 decrement 20
What's the difference if I configure the track object using the "ip routing" keywords instead, as follows:
track 1 interface s0/0/0 ip routing
In both cases, if interface s0/0/0 is down, it will trigger HSRP to reduce the priority by 20.
My understanding is, if only tracking of line protocol is required, we can configure the following method:
int fa 0/0
standby 1 track s0/0/0 20
Please advise.
Thank you.
B.Rgds,
Lim TS
uvaraj
If you configure "track 1 interface s0/0/0 line-protocol" it will check only the interface line status ie layer2 issues.
If you configure "track 1 interface s0/0/0 ip routing" it will check the layer3 issues routing issues.
Uvaraj
What type of routing issues associated with the interface? Neighbor adjacencies (e.g. OSPF, EIGRP)? What about if static routing is used instead? Or RIP?
Thank you.
B.Rgds,
Lim TS
Friend,
A tracked IP-route object is considered up and reachable when a routing-table entry exists for the route and the route is not inaccessible be it any routing protocol or even static.
have a look at this link
http://www.cisco.com/en/US/products/ps6566/products_feature_guide09186a008063c9bf.html#wp1047054
HTH, rate if it does
Narayan
Hi Narayan,
Thanks for the info. I know the command "track ip route".
However, my original question is about the difference between the following two commands:
track 1 interface line-protocol
track 1 interface ip routing
Thank you.
B.Rgds,
Lim TS
