08-06-2013 06:48 AM - edited 03-07-2019 02:46 PM
We are having 2 Cisco 1941 routers running as primary & secondary connection.
We have configured HSRP on both routers, but the HSRP state on both routers shows Active & Standby Unknown.
R1#sh standby gi0/1 brief
P indicates configured to preempt.
Interface Grp Pri P State Active Standby Virtual IP
Gi0/1 22 109 P Active local unknown 192.168.252.20
R2#sh standby gi0/1 brief
Gi0/1 22 105 P Active local unknown 192.168.252.20
below is the configuration for the interface Gi0/1 on both routers..
R1#sh run int gi0/1
interface GigabitEthernet0/1
ip address 192.168.252.21 255.255.255.0
standby 22 ip 192.168.252.20
standby 22 timers 1 3
standby 22 priority 109
standby 22 preempt delay minimum 300
standby 22 authentication Auth22
standby 22 track 1 decrement 10
ip ospf message-digest-key 1 md5 7 070C706E49
ip ospf cost 11
duplex auto
speed auto
end
R2#sh run int gi0/1
ip address 192.168.252.22 255.255.255.0
standby 22 priority 105
ip ospf message-digest-key 1 md5 7 011057265C
ip ospf cost 11
duplex auto
speed auto
end
OSPF key is same on both router.
Can anyone please help me to solve this problem?
Thanks.
08-06-2013 06:59 AM
Have you verfied that the layer3 interfaces can actually communicate with each other? Are you using a seperate switch to connect the two routers?
08-06-2013 07:10 AM
Yes, this is a common problem where both routers can't see each other so they both declare themselves to be master. Verify that the router interfaces are in the same VLAN.
