HTTP redirect using a Cisco 3750 switch
iirvine
Community Member
I have tried search but cound found anything for the 3750 switch about how to redirect HTTP, HTTPS & SMTP traffic to altenative gateway, than our standard gateway on our network, so here goes:
The network that need the HTTP, HTTPS and SMTP traffic redirect is 192.168.5.0/24 and should be redirect to 192.168.5.205 where as all other traffic need to be direct to 192.168.5.199.
Can the 3750 switch do this typo of refirect and if how?? Im pulling my hair out here as I can find anything on the Cisco site stating how or even if it is possible!  Any help on this would be appreciated.
Jon Marshall
Iain
I haven't tried using PBR sending the packets back out of the same vlan interface but you could try this -
Note that there are a couple of provisos
1) the switch must have IP Services image - IP Base does not support PBR
2) the switch must be running the routing template "sh sdm prefer" will show what template you are using. If you need to enable the routing template then the switch requires a reboot.
3) obviously the switch must be running ip routing
if the above are met then try this PBR config -
access-list 101 permit tcp 192.168.5.0 0.0.0.255 eq 25 any
access-list 101 permit tcp 192.168.5.0 0.0.0.255 eq 80 any
access-list 101 permit tcp 192.168.5.0 0.0.0.255 eq 443 any
route-map PBR permit 10
match ip address 101
set ip next-hop 192.168.5.205
int vlan xxx
ip address 192.168.5.x 255.255.255.0
ip policy route-map PBR
the above assumes you have a default route pointing to 192.169.5.199 so you only have to PBR the 192.168.5.205 destined traffic.
Jon
There is also a good document available here explaining how to configure and setup PBR with 3560/3750 switches
https://supportforums.cisco.com/community/netpro/network-infrastructure/routing/blog/2011/03/31/pbr-on-switches-37503560
