ospf to eigrp redistribution
benreynolds
Frequent Visitor
Frequent Visitor
Hi all,
I'm distributing ospf to eigrp (onto a MPLS WAN) via a cisco asa 5510 vers 8.2.5.
In short everything is generally ok but I am getting classfull networks redistributed from the ASA into the eigrp AS.
Heres an extract of the config if someone could scan:
access-list OSPFtoEIGRP standard permit 172.17.x.x 255.255.255.252
access-list OSPFtoEIGRP standard permit 10.0.x.x 255.255.252.0
access-list OSPFtoEIGRP standard permit 10.0.x.x 255.255.248.0
access-list OSPFtoEIGRP standard permit 10.0.x.x 255.255.240.0
access-list EIGRPtoOSPF standard permit 10.x.x.0 255.255.255.192
access-list EIGRPtoOSPF standard permit 10.x.x.128 255.255.255.240
access-list EIGRPtoOSPF standard permit 10.x.x.144 255.255.255.240
access-list EIGRPtoOSPF standard permit 10.x.x.192 255.255.255.192
route-map EIGRPtoOSPF permit 10
match ip address EIGRPtoOSPF
route-map OSPFtoEIGRP permit 10
match ip address OSPFtoEIGRP
router eigrp 9
no auto-summary
distribute-list OSPFtoEIGRP out ospf 100
distribute-list EIGRPtoOSPF in interface Outside
eigrp router-id 172.x.x.x
network 172.x.x.x 255.255.255.252
passive-interface Inside
redistribute ospf 100 metric 1000000 100 255 1 1500 route-map OSPFtoEIGRP
Heres the troublesome routes being distributed.
show eigrp top output:
P 10.0.0.0 255.0.0.0, 1 successors, FD is 28160
        via Redistributed (28160/0)
P 172.17.0.0 255.255.0.0, 1 successors, FD is 28160
The rest of the sh eigrp top looks good and is redistributing the required routes within net 10 etc.
regards
Ben
5 Replies 5
Reza Sharifi
Have you tried clearing the EIGRP process?
clear eigrp pid 9
Hi Reza - Thanks for the response - The ASA lets me clear the route within the process via:
clear eigrp 9 topology 10.0.0.0
but no clear eigrp pid 9 or clear eigrp 9.
I have also shut - no shut the interface to complete a hard reset for the adjacency in addition to
clear eigrp 9 neighbors outside which also results in the same issue being present.
think it's time to look at caveats on the IOS.
Best regards
Ben
zheng.olivier
Level 3
Level 3
I'm not sure that it may help but, "no auto-summary" in the ospf routing process.
Thanks for the suggestion Oliver.  OSPF is default as no auto-summary hence I'm unable to enter the command.
I've upgraded the IOS on the ASA now and I still see the same issue?  Must be somewhere in my config I think.  At least I hope so.
regards
Ben
From the show ip eigrp top output, you see that the routes are redistributed from OSPF, so I think the problem comes from the filtering.
I don't really get the reason why you filter using the route-map in the redistribute command and you filter using distribute list in the same time. The both call the same ACL (OSPFtoEIGRP) but there are used in 2 different directions (OSPF--> EIGRP via redistribute command and EIGRP-->OSPF via distribute list).
Maybe you're mix the direction of your distribute-list with the name of your ACLs : distribute out should use EIGRPtoOSPF (you're filtering the update send to OSPF process) and distribute in should use OSPFtoEIGRP.
