HWIC-AP-AG-A Not providing IP address to clients
adam.rogers
I have not yet completed my CCNA, however I have managed to configure a 1841 router with 1 x HWIC-ADSL1 and it also has 1 x HWIC-AG-AP-A which is the only part I am unable to get working.
The Wi-Fi (Dot11Radio) config has enabled me to see the SSID from wireless devices, but they never get an IP address. I need them to get the same IP range as the DHCP service I have in there 203.35.10.xxx, there is no option for "IP ADDRESS DHCP" only "IP ADDRESS POOL LAN" Lan is of course my DHCP pool name. however I cannot have the same DHCP pool on both Dot11Radio interfaces.
I know I'm missing one very simple command, but as I've never worked with Radio on Cisco equipment, I am unsure how to fix it.
Then once I get that worked out, I would also need help with changing the access from OPEN to WPA or WPA2, etc..
IOS Software on Router is C1841-ADVSECURITYK9-M - Version 12.4(9) T
I can upgrade to a better version of software if needed, I only have a 32mb Flash and 128Mb Ram.
Can someone help.
The current Radio Config is:
interface Dot11Radio0/1/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ssid xxxxxxxxx
authentication open
guest-mode
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
rts threshold 2312
station-role root
interface Dot11Radio0/1/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no ip route-cache cef
no ip route-cache
ssid xxxxxxxxxx-5GHz
authentication open
guest-mode
speed basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
rts threshold 2312
station-role root
adam.rogers
I have now managed to configure three selerate DHCP pools (LAN, SSID0 and SSID1), they are:
LAN: 203.35.10.xxx
SSID0: 203.35.11.xxx
SSID1: 203.35.12.xxx
I have set the default router to be xxx.xxx.xxx.1 relevant to each of the pools
I now get wireless connectivity, but no internet access on that wireless device.
