Hybrid Switchport Cisco
Tuff
Hi, I just started working with Huawei switches and it is possible to make a switchport hybrid port and tag untagged frames. See the below Huawei commands.
port link-type hybrid = command to make a switchport hybrid in Huawei
port trunk pvid vlan x = command to tag untagged traffic coming in on the trunk in Huawei
  Is there any Cisco switch or IOS that support hybrid mode like Huawei??
Leo Laohoo
I just read private vlans and i dont think it is the same.
This hybrid is for VoIP?
If yes then cisco have same and more config  for voice and data vlan in same swicthport
Hi, no it has nothing to do with voip. It is just the ability to make a switchport hybrid in Huawei switches and then be able to tag untagged traffic coming in on the trunk for example. I guess Cisco does not have such.
