I am new to cisco and need some help
frankie0722
I just bought some used routers. A 2524, 2520, 2516. When I went to go boot them up they got hung in the process. I am needing some help to find out what the problem maybe. A few people said to reinstall the IOS, well you can't do that if you can't get into them to setup a tftp. I can call anyone that is willing to help me with this. I would love to get them working and get my certs. Here is a copy of where it hangs at:
I am attaching a file so you can see where it hangs at.
frankie0722
I am attahing this to show the hang up during start up
Unfortunately I don't have time to find the links for you, but search CCO for 'password recovery for 2500'. This will give you the procedure to load the IOS without loading the config. See if this makes any difference.
Paul
try to get into ROMMON (by restarting the router and pressing Ctrl + Del within 10 seconds), and then use the XMODEM procedure detailed below:
Xmodem Console Download Procedure Using ROMmon
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
GNT
Press RETURN to get started!
