03-17-2009 07:50 AM - edited 03-06-2019 04:38 AM
1. I have a remote switch that ssh was enabled but it looks like the keys were not generated. How can I get to that switch
tried telnet ssh http
2. How can there be a rename config file in the flash.
6 -rwx 13223 Mar 16 2009 10:26:39 -05:00 config.text
7 -rwx 1530 Mar 16 2009 10:26:39 -05:00 private-config.text
8 -rwx 1048 Mar 16 2009 10:26:39 -05:00 multiple-fs
9 -rwx 13397 Feb 25 2009 14:16:40 -05:00 config.text.renamed
03-17-2009 09:03 AM
Hello James,
1) if the device is in the middle enabled only for ssh but with no keys configured I think someone has to access it in console to complete configuration or to disable ssh and allow for telnet on the vty
2) probably someone has made a copy of the configuration file some time ago
Hope to help
Giuseppe
03-17-2009 09:03 AM
If it was restricted to ssh then you will have to manually do it thru the console via a dialup or a directly connected pc to the console.
03-17-2009 09:05 AM
ok that is what I thought just seeing if there was a trick to do this
thanks
03-17-2009 09:09 AM
You need console access if SSH and Telnet is not properly configured.
Also if you have a file marked as renamed, it usually means there were a password recovery and you fallback to the express setup menu.
Laurent.
03-17-2009 09:16 AM
there are 2 different configs on those flash
how would I boot up with either flash config
03-17-2009 09:51 AM
The switch will use only config.txt file. That's why the extension is changed after a pw recovery so the swith will be with factory default settings meaning without any configuration. If you want to use the renamed config file, just remove the renamed extension by renaming the file to config.txt
Laurent.
03-17-2009 03:55 PM
Q: How can there be a rename config file in the flash?
A: Someone renamed the config.text file to config.text.renamed.
03-17-2009 04:08 PM
