Identifyting Model Using Serial Number
fmatulewicz
Community Member
I am verifying an inventory for a client for which my company is upgrading the network equipment. I have a few serial numbers without the model number on my inventory and wanted to know how I can look up a device and get the model number. I do not have access to the switches in question and was hoping this was available on cisco's web site..
23 Replies 23
device coverage check may give you the model numbers as well try it out here
**Please rate any helpful answers***
***Please rate all the useful posts***
-Prabath
Can this be obtained via an API ?
Mark Elsen
 Use this tool :
                https://cway.cisco.com/sncheck/
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Thanks, looking to do this via an API…
Thank you Marc .. It helped !!!
Dear Sir,
I know cisco ccrc web site I had used to check contract & serial numbers.
Currently I have more than 200 Serial numbers How to check bulk serial number contract details  status.
Please guide on this.
sachin
the tool you are looking for is the Device Serial Checker (linked below). You need CCO access, if you can't get to the tool, post the serial numbers here as a text file...
could u please check serial no; FDO244413YK. I have to replace DRIMMS
Dear Georg Pauwen, Thanks. I need the model No of this Cisco Switch Please. Serial no attached in a text file as asked by you.
  - @Cloud9 Enter the serial number in https://cway.cisco.com/sncheck/
  M.
Checked it says all unavailable. I don't know. What is the issue?
 - @Cloud9  - Please post a screenshot of the output you are observing ,
 M.
Is there a way to find the country of origin based off of the serial number? Trying to find the COO for FJC27431JKM
Each platform should have a sticker which will state what country it came from.
