IE-1000 SFP Not Forwarding
MarkFromAris
I have a IE-1000 switch with a GLC-LH-SMD plugged into port 9. The switch sees the SFP but won't pass traffic. What am I doing wrong?
MarkFromAris
Sorry. The problem was at the other end.
MarkFromAris
Reza Sharifi
Does the port actually come up?
MarkFromAris
No. The port just stayed dark. The trouble was the SG350 at the other end. Even though I changed the SG350 port speed to 1000, and it showed it on the webpage, it was stuck at 100. Once I rebooted the SG350, all worked.
Thanks.
Glad to know you found the issue. Good Luck!
