IE-3200-8P2S-E Required External Power Supply ??
kick534
Hi team
with IE-3200-8P2S-E we need to purchase external power supply or internal power Supply is there to power up POE devices.Such as CCTV cameras and IP Phones .
marce1000
 - Ref : https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-ie3200-rugged-series/cat-ie3200-rugged-series-ds.html
                             Check Table 4 and Table 7
 M.
thanks Marce i already go through with data sheet details,
Still confused that if i purchase a POE switch IE-3200-8P2S-E , should i need Power supply external.
because i need to connect also POE devices 240W , So by default the switch will power Up or need External PS.
a50573329
Dear Bro,
is the switch IE-3200-8P2S-E support POE if its connected with this power supply PWR-IE50W-AC-L ?
