IE-9320-16P8U4X-E POE port
Support ACME
Dear Sir,
i'm sourcing the industrial ethernet switch, the requirement is 8*10/100/1000BASE-T PoE++ Ports,16*10/100/1000BASE-T PoE+ Ports and 4*1G/10GBASE-X SFP Plus Ports. i checked the data sheet, "16 ports 10/100/1000M PoE+ and 8 ports 100/1000/2500M 4PPoE (up to 90W/port)", is it has 8 individual PoE++ port?
Support
Reza Sharifi
That switch comes with 8 ports of 100/1000/2500M 4PPoE, which means the switch supports what is called 4-pair PoE (4PPoE) or PoE++, able to supply up to 90W per port.
So, all 8 ports support up to 90W each.
Reza Sharifi
