Native VLAN mismatch detected on interface
mmarie
Hello
I have Cisco CBS350 switch connected to Cisco router C1128, just noticed the below error from the switch
 %CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected on interface gi1/0/1.
I tried to run the command: "show cdp neighbors gi1/0/1 secondary" and see that VLAN-ID is 0 while the switch VLAN is 425.
Holdtime: 160
Capabilities: Router Switch IGMP
VLAN-ID: 0
So how to solve it.
Appreciate your help
7 Replies 7
Richard Pidcock
You need to match the native vlan on each side of the connection.  Not exactly sure of the CLI commands on the CBS350 as I haven't worked with them much, but standard router and switch configurations would look similar to this below:
Router:
int Gix/x
 encapsulation dot1Q xxx native (where xxx is your vlan number)
Switch
int Gi1/0/1
 switchport trunk native vlan xxx (where xxx is your vlan number)
 switchport mode trunk
HTH,
Richard
Richard W. Pidcock
Blue_Bird
Hello mmarie ,
Native vlan must match both router and switch...
Router
interface Gigx/x
encapsulation dot1q vlan_id native
Please go through the following link...that may helps you change native vlan on  Cisco CBS350 switch:
https://www.youtube.com/watch?v=wIqBfc5k8kY
Best regards
******* If This Helps, Please Rate *******
mmarie
Thank you @Richard Pidcock  & @Blue_Bird
Here is the current configuration, the router port GigabitEthernet0/1/2 connected to port switch GigabitEthernet1/0/1
Router: sh ip int br
Interface              IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0/0   unassigned      YES NVRAM  up                    up
Gi0/0/0.425            172.18.158.85   YES NVRAM  up                    up
GigabitEthernet0/1/0   unassigned      YES unset  down                  down
GigabitEthernet0/1/1   unassigned      YES unset  down                  down
GigabitEthernet0/1/2   unassigned      YES unset  up                    up
GigabitEthernet0/1/3   unassigned      YES unset  down                  down
GigabitEthernet0/1/4   unassigned      YES unset  down                  down
GigabitEthernet0/1/5   unassigned      YES unset  down                  down
GigabitEthernet0/1/6   unassigned      YES unset  down                  down
GigabitEthernet0/1/7   unassigned      YES unset  down                  down
Router# sh run int GigabitEthernet0/1/2
Building configuration...
Current configuration : 38 bytes
interface GigabitEthernet0/1/2
end
Router# sh run int Gi0/0/0.425
Current configuration : 109 bytes
interface GigabitEthernet0/0/0.425
encapsulation dot1Q 425
ip address 172.18.158.85 255.255.255.252
end
Switch: show running-config interface gi1/0/1
interface GigabitEthernet1/0/1
switchport trunk native vlan 425
switchport trunk allowed vlan 425
But still get the "Native VLAN mismatch detected" message
Richard Pidcock
On your router add the native keyword onto your encapsulation statement.
encapsulation dot1Q 425 native
end
Richard W. Pidcock
if adding native keyword to encapsulation statement that will impact any traffic as its for ISP.
Also if i ignore the mismatch error that will cause any issue.
Thank you again
There will likely be a small hiccup when you add the native keyword as the interface will likely bounce.  However, this shouldn't be ignored as a native vlan mismatch is definitely going to give you problems.
Richard W. Pidcock
Who is your ISP ? What country are you in ?
