04-05-2022 11:38 PM
Does the PWR-IE170W-PC-DC power supply output its full power via one connector or does it require both output connectors to get the full capacity out of it? I am needing to have 2 to power a IE4010 switch to get the maximum POE capacity.
04-05-2022 11:55 PM - edited 04-05-2022 11:56 PM
IE4010 - you connecting to this device, and you looking to get a full 170W PoE is this correct.
as per the docs : ( you get max output power)
The switch do need some Power to startup as per my understanding :
I would advise to higher-level PSU suggested.
=====️ Preenayamo Vasudevam ️=====
04-06-2022 12:03 AM
01-18-2023 11:19 PM
The power supply data sheet does not mention if the outputs are in parallel or if they are independent.
