What is the difference between a C9200-Stack-Kit and a C9200L-Stack-Kit?
AWUWI
I have both types of stack kits but they have the same part numbers?
C9200-STACK V01
800-104767-01
Also is there any difference between C9200-STACK V01 and C9200-STACK V02?
Thank you in advance for your feedback.
15 Replies 15
Reza Sharifi
2 different kits, one is for the 9200 and the other one is for the 9200L
C9200-STACK-KIT
Stack kit for C9200 SKUs only: Two data stack adapters and one data stack cable
C9200L-STACK-KIT
Stack kit for C9200L SKUs only: Two data stack adapters and one data stack cable
Just different hardware revisions but the same functionality. If you are purchasing them, get the same revision number.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-stackwise-architecture-cte-en.html
Resa:
As I indicated in my posting I am seeing the same PID VID and part number for both types of stacking kits.  Could you please provide the PID VID and part number that is on the label for both types of kits?  Thank you.
Not sure if I follow your question. The link I provided has 2 different part numbers for 2 different products. One is for 9200 and the other one is for 9200L.
Sir ,
I have the same problem ,  Did you get the correct answer ?
could you provide me with the PID VID for the C9200L Stack kit or How can i know if it is compatibles with C9200l Switch
while the PID VID is c9200-stack V02
balaji.bandi
C9200 and C9200L are different models, but not to confuse in relation to stack cable.
jut make it order clear - when you ordering C9200 or order C9200-STACK-KIT if you decide to go C9200L order C9200L-STACK-KIT
@Reza Sharifi  provided the URL
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-stackwise-architecture-cte-en.html#_Toc13521183
Look below table some write up to give you more clarity.
BB
boonhong
Hi, can i stack C9200 to C9200L?
 - FYI : https://blog.router-switch.com/2019/05/5-faqs-of-cisco-catalyst-9000-stacking/#:~:text=Mixed%20stacking%20is%20not%20supported,X%20and%202960%2DXR%20Series.
 M.
it is not possible to mix the9200 and 9200L models due to different stacking bandwidth.
BB
No you cannot mix 9200 switches with 9200L switches in a stack. They have differing back plane speeds.
Thanks to everyone Can I use the 9200Stack Kit with two 9200L stacks? Also, is it possible to use the 9200LStack Kit in a stack configuration of two 9200s?
9200 X 2 - stack possible
9200L x 2 - stack possible.
if the question is regarding config, you can use same config
BB
Thank you Balaji What I want to know is whether I can configure a stack with two 9200Ls using two sets of 9200Stack kits. Or I would like to know if I can configure a stack with two 9200× using two sets ×of 9200LStack kits. Thank you very much for your response.
Stack kits are different look at the data sheet below stack kit when you ordering.
C9200-STACK-KIT
C9200L-STACK-KIT
BB
MS@TE
It's clear there are different SKU's for the stack kit and the 9200 and 9200L are not supportet to run in the same stack but:
We ordered the following SKU:
C9200L-STACK-KITCisco Catalyst 9200L Stack Module
But below inventory is displayed on the switch after installation:
NAME: "c92xxL Stack", DESCR: "c92xxL Stack"
PID: C9200L-48P-4X , VID: V02 , SN: FOC***
NAME: "Switch 1", DESCR: "C9200L-48P-4X"
NAME: "StackPort1/1", DESCR: "StackPort1/1"
PID: STACK-T4-50CM , VID: V02 , SN: LCC***
NAME: "StackPort1/2", DESCR: "StackPort1/2"
NAME: "StackAdapter1/1", DESCR: "StackAdapter1/1"
PID: C9200-STACK , VID: V02 , SN: JAE***
NAME: "StackAdapter1/2", DESCR: "StackAdapter1/2"
I'm missing the "L" in the PID for the stack adapters.
So my question is ... how can i clearly ensure that the installed stack adapters are from C9200L-STACK-KIT ?
Is there any difference on physical stack sdapter for 9200 and 9200L ?
