IE2000-8TC-G-E HSRP
mark.stewart1
HI,
I have 2 IE2000-8TC-G-E devices that I wish to HSRP between, issue being i dont seem to have available all the subset of the standby command.
They are both lanbase, if i set the below on a port, i get the standby command available:-
interface fFastEthernet1/8
no switchport
ip address 192.168.99.2 255.255.255.0
BUT when trying the standby command I do not get any of the IP subset of teh command available, if i try standby 1 ip 192.168.99.1 for example, i get ip unknown command, only options are showne below.
SwitchA(config-if)#standby ?
<0-255> group number
authentication Authentication
delay HSRP initialisation delay
follow Name of HSRP group to follow
mac-refresh Refresh MAC cache on switch by periodically sending packet
from virtual mac address
name Redundancy name string
preempt Overthrow lower priority Active routers
priority Priority level
redirect Configure sending of ICMP Redirect messages with an HSRP
virtual IP address as the gateway IP address
timers Hello and hold timers
track Priority tracking
version HSRP version
SwitchA(config-if)#standby 1 ?
anybody an ideas as to why??
Am i missing something big(probably)
Any help or advice appreciated.
license info and version:-
License Level: lanbase
License Type: Permanent
Next reload license Level: lanbase
Switch Ports Model SW Version SW Image
* 1 10 IE-2000-8TC-G-E 15.2(4)EA9 IE2000-UNIVERSALK9-M
marce1000
                                 - Not sure if that device can do it following :
            https://www.cisco.com/c/nl_nl/support/switches/ie-2000-8tc-g-e-industrial-ethernet-switch/model.html
  Search in the documentation field for HSRP , nothing was returned. This guide :
            https://www.cisco.com/c/en/us/td/docs/switches/connectedgrid/cg-switch-sw-master/software/configuration/guide/availability/Availability/red_over.html
 mentions  IE 2000U      model....
 M.
marce1000
 M.
mark.stewart1
Yep it looks like it is only fully available on the 2000U version.
thanks,
mark.
