Bookmark
Subscribe
1621
IE2000 Series Switch
juliangriba
FA1/5-1/6 should be GI1/1-1/2FA1/5-1/6 should be GI1/1-1/2
Any reason why the unit is indicating all ports as FAX/X when in fact it should be indicating two GI ports?. Is there a way to solve this hardware configuration? FA1/5 and FA1/6 should be Gi1/1 and GI1/2.. Thank You.
7 Replies 7
marce1000
 - Dpes show int gi1/1 work (as an example-test so to speak) ?
   M.
NewSwitch#sh interface GI1/1
% Invalid input detected at '^' marker.
Here is the result when I enter "sh interfaces"
FastEthernet1/5 is down, line protocol is down (notconnect)
Hardware is Fast Ethernet, address is f07f.06e1.8d85 (bia f07f.06e1.8d85)
MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is Not Present
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
marce1000
 Ref : https://www.cisco.com/c/en/us/td/docs/switches/lan/cisco_ie2000/hardware/installation/guide/ie2000_hig.pdf
 You are probably hitting this :
  Dual-Purpose Gigabit Ethernet Uplink Ports
You can configure the dual-purpose Gigabit Ethernet uplink ports on the switch as either 10/1001000BASE-T ports or
as 100/1000 Mb/s SFP-module ports. You can set the 10/100/1000BASE-T ports to autonegotiate, or you can configure
them as fixed 10, 100, or 1000 Mb/s (Gigabit) Ethernet ports.
By default, the switch selects the medium for each dual-purpose port (10/100/1000BASE-T or SFP). When a link is
achieved on one media type, the switch disables the other media type until the active link goes down. If links are active
on both media, the SFP-module port has priority, but you can use the media-type interface configuration command to
manually designate the port as an RJ-45 port or an SFP port.
You can configure the speed and duplex settings consistent with the selected media type. For information on configuring
interfaces, see the switch software configuration guide.
 M.
This a IE-2000-4TS, four ethernet ports and two ports for SFP. That concept applies to dual ports no in this case. Thanks for your advice.
 = Do you have the full part number of the switch (you can also get that with the show version command), because from the referenced link below  , I can see that the  IE-2000-4TS-B only has 100Mb ports
  https://www.cisco.com/c/en/us/td/docs/switches/lan/cisco_ie2000/hardware/installation/guide/ie2000_hig/HIGOVERV.html#57433
 M.
IE-2000-4TS-G-B-U..
 - I don't know what the -U extension means (for the moment), but it is in the -G-B-xxx train, which is probably bad news.
 M.
