IE3200 killed with Upgrade? Upgrade Path?
thomas.lutz
I upgraded an IE3200 from IOS XE 16.10.x to 17.12.x
Since I haven't found a special upgrade path I thought this would be ok.
Is there a special upgrade path from 16.10.x to 17.12.x?
Now the switch boots 17.12.x, shows following an reboots
*Jan  7 22:02:50.473: PHY-EMI: Fix failed for phy port 2
*Jan  7 22:02:50.473: PHY-EMI: Enable link failed for phy port 2
*Jan  7 22:02:50.474: PHY-PLL: PLL init failed for Phy port 3Mdio port 1
*Jan  7 22:02:50.474: OIR Error:PHY PLL config Failed port 3
*Jan  7 22:02:50.474: SUP-OIR ERR:Fail to Init Down Link Ports
*Jan  7 22:02:50.474:  Error SUP OIR Failed !!!
UNIX-EXT-SIGNAL: Segmentation fault(11), Process = Profinet Pnak -Traceback= 1#e72ba1c969fc598a9709383d0aefcd49 :55656AF000+3A95570 :55656AF000+3A94D60 iosd_crb_petra_unix:7F80BB0000+701B4 linux-vdso:7F845CF000+5E0 :55656AF000+908C268 :55656AF000+2FAEEA0 :55656AF000+2FBB990 :55656AF000+2F19EC0 :55656AF000+2F08B88 :55656AF000+2FE1BA0 :55656AF000+2FD6D8C :55656AF000+2FF4A18 :55656AF000+2FFAA44 :55656AF000+2C81ED8 Fastpath Thread backtrace: -Traceback= 1#e72ba1c969fc598a9709383d0aefcd49 iosd_crb_petra_unix:7F80BB0000+70304 linux-vdso:7F845CF000+5E0 c:7F6FA7E000+D11EC iosd_crb_petra_unix:7F80BB0000+3B6C4 prelib:7F80B90000+7D9C pthread:7F6F970000+7DD4 c:7F6FA7E000+D105C Packet Thread backtrace: -Traceback= 1#e72ba1c969fc598a9709383d0aefcd49 iosd_crb_petra_unix:7F80BB0000+70304 linux-vdso:7F845CF000+5E0 c:7F6FA7E000+D11EC iosd_crb_petra_unix:7F80BB0000+68784 prelib:7F80B90000+7D9C pthread:7F6F970000+7DD4 c:7F6FA7E000+D105C Auxiliary Thread backtrace: -Traceback= 1#e72ba1c969fc598a9709383d0aefcd49 iosd_crb_petra_unix:7F80BB0000+70304 linux-vdso:7F845CF000+5E0 pthread:7F6F970000+E1C0 iosd_crb_petra_unix:7F80BB0000+77338 prelib:7F80B90000+7D9C pthread:7F6F970000+7DD4 c:7F6FA7E000+D105C Worker Thread 1 backtrace: -Traceback= 1#e72ba1c969fc598a9709383d0aefcd49 iosd_crb_petra_unix:7F80BB0000+70304 linux-vdso:7F845CF000+5E0 pthread:7F6F970000+E1C0 thpool:7F7B339000+1E6C prelib:7F80B90000+7D9C pthread:7F6F970000+7DD4 c:7F6FA7E000+D105C Worker Thread 2 backtrace: -Traceback= 1#e72ba1c969fc598a9709383d0aefcd49 iosd_crb_petra_unix:7F80BB0000+70304 linux-vdso:7F845CF000+5E0 pthread:7F6F970000+E1C0 thpool:7F7B339000+1E6C prelib:7F80B90000+7D9C pthread:7F6F970000+7DD4 c:7F6FA7E000+D105C
I the short time, I can input cli commands, I can see, that the switch online shows interface vlan 1.
Interface gi 1/1-10 is missing.
Can that be fixed?
Did I kill the switch?
regards,
Thomas
Contact Cisco TAC and organize for an RMA.  The switch is dead.
11 Replies 11
Mark Elsen
   - Not sure why this happened ; check if this can help you :
                 https://www.cisco.com/c/en/us/td/docs/switches/lan/cisco_ie3X00/Hardware/installation/guide/emergency-recovery-ie3x00.html
   M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Leo Laohoo
Post the complete output to the command "sh profinet status".
sell below
If this network is not using Profinet, turn it off.
thomas.lutz
I can boot Emergency Recovery IOS XS 16.12 from the switch.
It does not reboot, but int gi1/1-10 are not shown. Only vlan1.
I booted 17.12.04 from usbflash and did a factory default.
Installed 17.12.04 again -> reboots
LED of gi1/1, 1/2 and 1/4 are solid orange.
it also shows at boot of 17.12.04
imsp_led_init: fail to get max physical port for slot =1
Switch#sh profinet status
Profinet                        : Enabled
Connection Status               : Disconnected
Vlan                            : 1
Profinet ID                     :
GSD version                     : Unknown
Reduct Ratio                    : 128
MRP                             : Enabled
MRP License Status              : Not Applicable
MRP Max Rings Allowed           : 3
Switch#no profinet
Switch#show profinet status
Profinet                        : Disabled
Vlan                            : 1
Profinet ID                     :
Reduct Ratio                    : 128
MRP                             : Enabled
 Disable profinet didn't help.
Still reboots with "
 See attached crashinfo
  - @thomas.lutz   - It looks  like the device got 'damaged' for some reason ; try full power cycle but
                               attach a console first and watch the output, look for errors on startup if any.
                                        + If that does not  help also try factory reset ,
  M.
       Beauty and terror
      Just keep going
       No feeling is final
thomas.lutz
I managed to factory default and install 17.3.6 with no rebooting.
But at boot it shows
*Jan  8 04:16:28.409: PHY-EMI: Disable link failed for phy port 0
*Jan  8 04:16:28.409: PHY-EMI: Fix failed for phy port 0
*Jan  8 04:16:28.409: PHY-EMI: Enable link failed for phy port 0
*Jan  8 04:16:28.410: PHY-EMI: Disable link failed for phy port 1
*Jan  8 04:16:28.410: PHY-EMI: Fix failed for phy port 1
*Jan  8 04:16:28.410: PHY-EMI: Enable link failed for phy port 1
*Jan  8 04:16:28.411: PHY-EMI: Disable link failed for phy port 2
*Jan  8 04:16:28.411: PHY-EMI: Fix failed for phy port 2
*Jan  8 04:16:28.411: PHY-EMI: Enable link failed for phy port 2
*Jan  8 04:16:28.411: PHY-PLL: PLL init failed for Phy port 3Mdio port 1
*Jan  8 04:16:28.411: OIR Error:PHY PLL config Failed port 3
*Jan  8 04:16:28.411: SUP-OIR ERR:Fail to Init Down Link Ports
*Jan  8 04:16:28.411:  Error SUP OIR Failed !!!
Is this a hardware error?
    - Can you boot the 16.x version that the device was (still) working with ?
  M.
       Beauty and terror
      Just keep going
       No feeling is final
Post the complete output to the command "sh post".
If POST is not enable, connect a console cable to the switch and reboot again.  Post the entire boot-up process.
17.3.6 doesn't reboot, 172.12.4 does reboot, both don't show interfaces
