IE3300 Layer 2 NAT Per All
Please consider below topology in which I have 1 core Switch which have 2 SVI VLAN 10(192.168.10.1) and VLAN 20(192.168.20.1) and 2 access switches(IE3300) which are acting as layer 2 device. AS1 has 2 PC connected and AS2 also has the same. All the switches forming a RING and REP has been used as Ring Protocol. Everything is working fine.
PC 1 : 10.0.0.1, PC 2 : 10.0.0.2, PC 3 : 10.0.0.1, PC 4 : 10.0.0.2 IP are duplicate. That is fine. I have introduced a L2NAT in both the switches, for Switch 1 am translating all the IP in PC's to VLAN 10 series and for Switch 2 I am translating it to VLAN 20 series for all the PC in Switch 2. That is also fine. I am confused about Permit All command, if I execute permit all will there be any issue. Because I am facing an issue, If I am  executing permit all command PC1 and PC2 which are on same switches are dropping frequently.
12 Replies 12
ammahend
Your setup looks similar to figure 2 here
make sure your config is as per the example shown
-hope this helps-
Hello
Its unclear why you are dropping packets at this time when you enable permit all in the L2NAT instance.
The Permit ALL in the L2NAT instance acts just like an access-list does so without it there is an implicit deny for packets that do not match, however allowing all traffic when in a L2NAT access mode design can potentially cause broadcast traffic to the other hosts sharing the same vlan on your other IE switches, which could be negated if you changed to a routed access design.
I see in your diagram above you have the IE switches interconnected, what happens if you break that REP ring between those IE switches and then enable enable permit all on the L2NAT instances?
Kind Regards
Paul
Hello Thanks for your brief, info.
You mentioned that there will be broadcast tariff, so I believe it will be on the same Vlan not broadcast from VLAN 10 to VLAN 20.
I did not tried breaking up the ring as it is production network. L2NAT has been passed on both Gig interfaces.
Also, one thing I want to understand that, I have router  connected above the core switches and core Switches can learn routes from router. Lets say 172.16.10.10 learning from static route. So I am doing the translation like.
Inside from host 10.0.0.1 to 192.168.10.101
Outside from host 172.16.10.10 to 10.0.0.10.
Inside PC can reach 10.0.0.10 as well, router can also ping 192.168.10.101 but only after providing once permit all, then removing permit all keeps on working, but at the same time local PC causes RTO.
NOTE : Customer cannot put Gateway on end device due to legacy device.
The outside host should see your inside hosts as 192.168.x.x  host
The inside hosts should see your outside host as 10.0.0.10
So you must be using proxy-arp to gain external connectivity as such your fix-up is set to ALL correct??
Can you share the cfg of the core and a IE switch please if applicable?
Kind Regards
Paul
My topology looks something like this and below is the basic config.
l2nat instance VLAN10
fixup : arp, icmp
outside from host 172.16.10.10 to 10.0.0.100
inside from host 10.0.0.10 to 192.168.10.10
outside from host 192.168.10.1 to 10.0.0.101
interface GigabitEthernet1/1
switchport mode trunk
l2nat VLAN10 10
rep segment 1
interface GigabitEthernet1/2
l2nat VLAN10 10
rep segment 1
This is the packet tracert scenario, It which it is working fine as packet tracer if not having permit all functionality. But in my scenario there are multiple switches in a Ring, which have different L2NAT instance Running on both the Uplink and downlink port that is why I am running permit all.
I think this your third post about l2 NAT IE3300' as I remember I share YouTube link about l2 NAT
Can you double check it
MHM
Thanks for sharing the Youtube Link, I went through the full video but unfortunately, there is not information which I require now.
Hello
Fyi - permit all IS recommended  on the L2NAT instance
As for the the pc1/2 that are in the same vlan could be due to BUM traffic -the L2 and the fact your hosts don’t have any D/G
you don’t mention how large of ring topology you have however if the requirement is to have resilient IE topology between the core and other IE switches and run L2NAT at each IE switch then i would look into running  L3 on each IE switch and let them perform both functions (routing - L2NAT) - routed-access design
Having dynamic routing such as eigrp between the core and IE switches you will not require any rep -each IE will L2nat its own vlan without any outside local or gateway 1-2-1 mapping  and you’ll have full resilient connection between each IE switch host and externally
Kind Regards
Paul
FYi, I have 9 switches forming a Ring with REP protocol and as it is ring so L2nat instance has been called on both the uplink and downlink interfaces.
If I understand correctly, you means to perform the routing at IE end instead of Core layer. How ring will.be formed in this case.? Also As I mentioned that I cannot add a gateway to machines.
Hello @Himanshu_Dwivedi
TBH thinking about it a bit more Im not so sure the routed access mode would be a viable option, the problem is the ring topology, you would have peering issues that would need to be negated plus the L2nat instance can only be applied to L2 interfaces anyway.
Kind Regards
Paul
I have found  L2NAT video in which they are configuring L2NAT in Ring, in which Permit All is suggested, but the ring is in access mode, as all the switches uplink and downlinad are on access port. In my case it is trunk, hopefully it should work
Hello
if that is applicable to your own topology then try that it, I would say it much better then having trunks interconnecting
Kind Regards
Paul
