IGMP Configuration
sheraz butt
Level 2
Level 2
Hi All,
I Want to configure IGMP snooping for IPTV server  i configured IPTV vlan 30 all connectivity are okay just need commands for CORE switch CAT4507 And access switch 2960 only for IGMP.
IPTV-Server>>>>CAT4507+E>>>>>>2960PSL>>>>>STB+TV
Help will be appriciated
7 Replies 7
Jon Marshall
Are you only trying to do this within vlan 30 or do you want to route between vlans for the multicast stream ?
Jon
Thanks for the Quick Respo... BRO
for vlan 30 only will be best becoz i have vlans for CAM,DATA,VOICE below are the ports for IPTV in access switch.
interface gigabitEthernet 1/0/4
switchport mode access
switchport access vlan 30
spanning-tree portfast
no shut
exit
interface gigabitEthernet 1/0/5
no shut
exit
interface gigabitEthernet 1/0/8
no shut
exit
interface gigabitEthernet 1/0/12
no shut
exit
Best Regards
If you are only doing it in one vlan then you need to have  -
1) IGMP snooping enabled. This should be enabled by default
2) an IGMP snooping querier enabled so that the switch makes IGMP queries for that vlan. You only need to configure this on one switch. The 4500 would be a good choice. See this link for configuring it -
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/50sg/configuration/guide/multi.html#wp1163784
Jon
Thanks again ,,,
       Problem is i am havin very basic knowldge abt switching what i understand.
1) i have to enable IGMP on spesfic vlan (ip igmp snooping vlan 30 ) on core switch
2) IGMP snooping querier (ip address of IPTV server ?)
3) no need to do anything in access switch my port configuration is okay ?
but if someone leave the stream the switch port will relax means gose normal immediately.
HAPPY CRISTMAS
1) You shouldn't have to as it should be enabled by default on both switches
2) The address should be the L3 vlan IP assigned to vlan 30 on the 4500.
3) your configuration is fine for the ports.
Happy Christmas to you as well
Jon
HI Mr JON,
          I  don,t know you are still available or not but i am facing a issue with same network i added one more ip head-end (DVB-Streamer) but traffic  flooded on stb middleware ip head-end and all STB,s are in same vlan 30.
Streamer,s broadcast ip address range is
streamer1 -239.99.1.x
streamer2 -239.88.1.x
CORE1#sh ip igmp snooping querier
Vlan      IP Address               IGMP Version   Port
30        10.121.55.1              v2            Switch
CORE1#sh ip igmp snooping groups
Vlan      Group                    Version     Port List
30        239.88.1.1               v2          Gi1/28, Gi2/13, Gi2/25
30        239.88.1.2               v2          Gi1/19, Gi2/16
30        239.88.2.1               v2          Gi1/1, Gi1/36, Gi2/19
30        239.88.3.1               v2          Gi2/18
30        239.88.4.1               v2          Gi1/6, Gi1/17, Gi1/29,
                                                           Gi1/34, Gi1/38, Gi1/46
30        239.99.1.32              v2          Gi1/9, Gi1/10, Gi1/13,
                                                           Gi1/15, Gi1/16, Gi1/22,
                                                           Gi1/25, Gi1/26, Gi1/27,
                                                           Gi1/30, Gi1/32, Gi1/41,
                                                           Gi1/42, Gi1/47, Gi1/48
30        239.99.1.33              v2          Gi1/24
30        239.99.1.34              v2          Gi1/2, Gi1/33, Gi2/14
30        239.99.1.35              v2          Gi1/7
30        239.99.1.50              v2          Gi1/4
30        239.99.1.52              v2          Gi1/21
30        239.99.2.32              v2          Gi1/45
30        239.99.2.36              v2          Gi1/5, Gi1/18, Gi1/20,
                                                           Gi1/31, Gi1/35, Gi2/1,
                                                           Gi2/6, Gi2/18
30        239.99.3.14              v2          Gi1/3, Gi1/14, Gi1/40,
                                                           Gi1/43
30        239.99.5.7               v2          Gi1/8
30        239.99.5.21              v2          Gi2/4
30        239.255.255.250          v2          Gi1/1, Gi1/2, Gi1/3,
                                                           Gi1/4, Gi1/5, Gi1/6,
                                                           Gi1/7, Gi1/8, Gi1/9,
                                                           Gi1/10, Gi1/13, Gi1/14,
                                                           Gi1/15, Gi1/16, Gi1/17,
                                                           Gi1/18, Gi1/19, Gi1/20,
                                                           Gi1/21, Gi1/22, Gi1/24,
                                                           Gi1/28, Gi1/29, Gi1/30,
                                                           Gi1/31, Gi1/32, Gi1/33,
                                                           Gi1/34, Gi1/35, Gi1/36,
                                                           Gi1/38, Gi1/40, Gi1/41,
                                                           Gi1/42, Gi1/43, Gi1/45,
                                                           Gi1/46, Gi1/47, Gi1/48,
                                                           Gi2/1, Gi2/4, Gi2/6,
                                                           Gi2/13, Gi2/14, Gi2/16,
                                                           Gi2/18, Gi2/19, Gi2/25
CORE1#sh ip igmp snooping mrouter
Vlan    ports
  30    Switch
CORE1#sh processes cpu history
    211121121213221111111121211121211212131111111222422232323221
    683419325641925654565575945434483352607645454641216617190956
100
 90
 80
 70
 60
 50        *
 40                                                 *                   ** *
 30 *        * **         * *            *       *  * *********   *  *******
 20 **  ** *** ****** ******* * * ** ******* * * ***************************
 10 ########################################################################
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                       CPU% per hour (last 72 hours)
                    * = maximum CPU%   # = average CPU%
Any Help
Hi  sheraz
i hope you are fine
sheraz now i have new IPTV project for hotel
but i'm just want to ask you about client interface on the access switch speed,
all my access switches are WS-C2960+48PST-S
and core switch is CISCO 3650
the interface speed 100MB so there is any problem with it or now ?
and what about the interfaces bandwidth in your access switches
please answer me because it's major case for my project
have nice day
thanks
