08-16-2013 07:39 AM - edited 03-07-2019 02:58 PM
Hi all
I ran into a problem with VIP for high availability on Blue Coat ProxySG. Both ProxySG send multicast packets
to advise the other ProxySG that it is up and the priority is contained in the multicast packet, along with the IP address of the VIP and so on.
This worked fine with Catalyst switches. Unfortunately it does not work over the newly installed Nexus switches.
There is no Vlan interface on the switches. The Vlan is only trunked through.
I found a hint that IGMP Querier could solve this issue. After configuration of IGMP Querier end acitvating Multicast on ProxySG
a IGMP group is built and all seems fine.
In a trace I can see IGMP Queries leaving the Querier but no answer from both ProxySGs.
After 6 minutes (3 times Querier Interval) the group disappears and both Boxes become active.
The topology looks like this:
Bluecoat1 -----N2k------2*N5k-----2*N7k-------Inter Datacenter Link-------2*N7k------2*N5k-----N2k-----Bluecoat2
vPC vPC vPC vPC
On both N7k in the left Datacenter is a Querier configured:
vlan configuration 85
ip igmp snooping querier 10.101.22.7
# sh ip igmp snoop querier
Vlan IP Address Version Expires Port
85 10.101.22.7 v3 00:01:22 Switch querier
I wonder if an additional setting has to be made. Could it be that the Bluecoats ignore IGMPv3?
I would be very grateful for a hint.
Many Thanks!
Urs
Solved! Go to Solution.
08-16-2013 05:47 PM
If the VLAN is only used for Bluecoat, maybe you can disable igmp snooping on that VLAN.
HTH,
Lei Tian
08-16-2013 05:47 PM
HTH,
Lei Tian
08-19-2013 02:07 AM
great idea. It works. As only the Bluecoats are in this VLAN we decided to leave snooping deactivated.
Many Thanks!
Best Regards,
Urs
07-15-2014 02:42 AM
I am exeperiencing the same issue described above, with a similar network layout:
BlueCoat1---N2K---2*N5K(vPC)---2*C6880(VSS)---Inter Datacenter Links---2*C6880(VSS)---2*N5K(vPC)---N2K---BlueCoat2
I have configured an IGMP querier in the BlueCoat VLANs on both 2*N5K(vPC), even if on one 2*N5K(vPC) should be enough.
For each VLAN I've used the same free IP-Address on all 4 N5K:
Is that correct?
I am asking, bacause the Cisco-documetation says, that only the one with the "lowest IP-Address (?)" will be active:
How should the IGMP-Querier-election work in my case?
Any help will be really appreciated.
Many thanks
02-02-2016 12:55 AM
hello,
we are exeperiencing the same issue described above, with a similar network layout
and we are changend muticast adresse with the ip on the range
224.0.0.69-224.0.0.100 Reserved [IANA]
02-29-2016 02:32 AM
Yes !
Changed Blue Coat ProxySG failover multicast addresses to 224.0.0.80-82.
Its work !
